text color
MisterMaker
text color
Post by MisterMaker »
I was doing some testing on the 0.2 beta since I needed to make a cnc program.
I noticed that the text in the horizontal feedrates and vertical feedrates is a bit dark and in some theme's barely readable. (Note it is pretty good readable on the screenshot below but on my screen it's not)
It stays the same black on the white theme and it is very good readable on a light theme. so it has the opposite effect on the light theme.
Also I wondered if the naming shouldn't be:
X/Y feedrates
Z feedrate
X/Y Rapids
Z Rapids
These axis should be standardized as far as I was though like below coordinate system.
Edit also in
Also in
Tool library background is white text on gray background:
Re: text color
Post by Kunda1 »
I think this thread summary name is too vague and ambiguous. Please consider renaming it to attract the correct attention. TIA
