[SOLVED] Difficulties installing OpenCamLib
103131
Post by 103131 »
Hi everyone, :)
I'm looking to 3D carve a small relief shape on wood to test. Then I will sculpt something more complicated. I understand that to do this I need to install OpenCamLib. Unfortunately for now, I can't. I followed several tutorials for this, including recently this one:
https://forum.freecadweb.org/viewtopic.php?t=53640
When I type the command:
git clone git://github.com/aewallin/opencamlib.git
Each time I get the following error message :o :
Cloning in 'opencamlib'...
fatal: unable to connect to github.com:
github.com[0:140.82.121.3]: errno=Connection terminated due to timeout
Could someone tell me what I need to do? I'm no expert and really don't know what to do.
I specify that I have an Ubuntu 20.04.
Thanking you in advance. :)
herbk
Re: Difficulties installing OpenCamLib
Post by herbk »
the most easy way is to use the Appimage... ;) ;)
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
At Anders Wallins GitHub ACC are some infos to, but may be outdated.
https://github.com/aewallin/opencamlib
Gruß Herbert
103131
Post by 103131 »
Thank you for your answer. :)
But I already use the Appimage and update it regularly.
And I already know the address you give:
The problem is that when I run the command in a console:
Nothing happens and after a while I estimate two to three minutes I get the following message:
So I can't go any further.
Kuzma30
Post by Kuzma30 »
RealThunder's A3 Wiki translation, join the project https://crowdin.com/project/freecad-asm3-wiki
103131
Post by 103131 »
But I don't understand why you're asking me that. In the process explained on this page, at some point in a console, we have to write the command:
And that's where it doesn't work.
Kuzma30
Post by Kuzma30 »
If you get error when git clone with git protocol you can try it with https interface.
Russ4262
Post by Russ4262 »
Evening.
I am a Windows user, and the Windows weekly builds have OCL bundled in the binary package. Do the AppImages not have it bundled in the image? You can check by running the AppImage and then typing
import ocl
in the Python console in FreeCAD. If no error is thrown, it is bundled and available. This means you will only need to address preferences and parameters in FreeCAD to gain access to OCL dependent ops.
Russell
OS: Windows 10 Version 2009
Version: 0.20.28914 +9 (Git)
Branch: master_prs
Hash: 372c0025e2d72d8f06bcd74eb9b8b393db965f92
Python 3.8.6+, Qt 5.15.2, Coin 4.0.1, OCC 7.5.0
Installed mods:
  * FC_SU
  * Z_MacroStartup
Steveco
Post by Steveco »
Github no longer supports the git:// protocol - see Improving Git protocol security on GitHub.
Try
git clone https://github.com/aewallin/opencamlib.git
That worked for me, and I'm also on Ubuntu 20.04.
103131
Post by 103131 »
Hi everyone :)
I just tried this morning with the command:
It seems to me that everything went well.
But when I go to Freecad, I still don't see ocl.
In freecad 0.19, when I type:
import ocl
in the python console, I get the following message:
>>> import ocl
ModuleNotFoundError: No module named 'ocl'
And when I type the same command in the python console of Freecad 0.20, nothing happens. :(
Russ4262
Post by Russ4262 »
103131 wrote: Sun May 22, 2022 9:11 am ...
Morning,
After cloning the repo, you have to build it. Cloning it only copies the online repository to your local computer. There are some instructions in the FreeCAD wiki on the OpenCamLib page.
Russell
