[SOLVED] No GCode except for pre- and postamble after postprocessing
Samu
Post by Samu »
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: d492ac30838e4fb07b1ce4b378730f2fb38b9ba3
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Installed mods:
  * Render 2022.1.0
  * A2plus
  * CurvedShapes
  * FeedsAndSpeeds 0.4.0
When I create the operations in the attached file with the attached Macro only the pre- and postamble are showing up in my .ngc file.
The macro creates paths to machine fillets with the edge of an endmill on 'inside' holes where you can not used a toolbit designed for processing fillets.
It is applied by selecting the fillet face you want to machine and run the Macro.
The approach in the Macro is mostly an adapted copy of this video series by sliptonic https://www.youtube.com/watch?v=Ic9Kip5ufDE and it used to work until a couple of updates ago and still works in e.g. the FC version below:
Version: 0.19.23756 (Git) AppImage
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
The described behaviour is independent of the postprocessor used (tried linuxcnc, haidenhein, fanuc and a couple of my own postprocessors)
Does anyone have an idea why it's not working anymore?
PS:
The Macro is used to 'emulate' a 4/5 axis mill on chamfers parallel to the y-axis by cutting only with the cutter edge of an endmill. It's very useful if you do not have 4 or 5 axis or if they can not be used due to collision between spindle and part.
It could easily be modified to chamfers not parallel to any axis if someone would need it.
Additionally I have a version for fillets as well.
Ramps_paths.FCMacro
(2.15 KiB) Downloaded 18 times
Fis_Double_Bottom_Ramps_Passstifte.FCStd
(120.08 KiB) Downloaded 16 times
Samu
Re: No GCode except for pre- and postamble after postprocessing
Post by Samu »
Update:
if I use
Qt version: 5.12.5
OCC version: 7.4.0
I get the following error thrown at me after postprocessing:
14:10:00  Traceback (most recent call last):
  File "/tmp/.mount_FreeCABbMY3l/usr/Mod/Path/PathScripts/PathJob.py", line 400, in execute
    obj.Path = obj.Operations.Path
<class 'AttributeError'>: 'App.DocumentObjectGroup' object has no attribute 'Path'
However, the gcode is still postprocessed correctly and I clearly add a 'Path' to the job in the Macro as well.
In the 'PathJob.py' in version:
Version: 0.20.
Branch: unknown
Installed mods:
  * Render 2022.1.0
  * A2plus
  * CurvedShapes
the line 672 which throws the error:
670    def execute(self, obj):
671        if getattr(obj, "Operations", None):
672            # obj.Path = obj.Operations.Path
673            self.getCycleTime()
is commented out. That keeps me wondering if something has changed in the way paths/operations are added to a job so that my approach in the Macro does not work anymore?
sliptonic
Post by sliptonic »
Several things have changed in that might affect your macro.
This PR was the biggest change.
https://github.com/FreeCAD/FreeCAD/pull/4911
Samu
Post by Samu »
sliptonic wrote: Tue May 31, 2022 2:06 pm Several things have changed in that might affect your macro.
Thank you for your reply.
The solution was found in PathPost.py:
357                if not PathUtil.opProperty(obj, "Active"):
358                    continue
I was simply missing:
o.addProperty('App::PropertyBool', 'Active', 'Path')
o.Active = True
The Macro is now working perfectly again
Ramps_paths.FCMacro
(2.38 KiB) Downloaded 16 times
