Colleagues,
there is a question to the additional options of the created operation. Dogbone & leadinout. It is not possible to apply them both (sequentially or in parallel) to the same operation. Either only gogbone or leadinout is possible. Agree, this is wrong - it should be possible to apply both additional options.
Besides, there is a problem in the leadinoiut implementation - in the settings you can set the "do not lift the tool" option, but when you implement this option, the transition between the leadout end point and the leadin start point is implemented as G0, while it should be G1. This will cause the tool to break.
