[Bug] Camotics import error in 0.21_pre [Fixed]
Russ4262
Post by Russ4262 »
Afternoon,
Can anyone verify the following error in 0.21_pre.
Steps to reproduce:
  1. Start FreeCAD.
  2. Red error in Report view. - ERROR #1
    No module named 'camotics'
  3. Switch to Path workbench, and it fails to load Path toolbars. - ERROR #2 - see screenshot
  4. Open existing Path project file (>= 0.19).
  5. Error thrown in Report view related to PathCamoticsGui. - ERROR #3
      File "C:\Users\Public\Documents\FreeCAD_Install\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
      File "C:\Users\Public\Documents\FreeCAD_Install\Mod\Path\PathScripts\PathJobGui.py", line 1657, in <module>
        PathGuiInit.Startup()
      File "C:\Users\Public\Documents\FreeCAD_Install\Mod\Path\PathScripts\PathGuiInit.py", line 71, in Startup
        from PathScripts import PathCamoticsGui
      File "C:\Users\Public\Documents\FreeCAD_Install\Mod\Path\PathScripts\PathCamoticsGui.py", line 32, in <module>
        import camotics
    <class 'ModuleNotFoundError'>: No module named 'camotics'
Thanks,
Russell
OS: Windows 10 Version 2009
Version: 0.21.29324 (Git)
Hash: 3a86b1719495abb825c4280f154d809ce4fed1b1
Installed mods:
  * FC_SU
  * Z_MacroStartup
Path workbench not loading after camotics error
Snip macro screenshot-ef4862.png (92.42 KiB) Viewed 680 times
GeneFC
Re: [Bug] Camotics import error in 0.21_pre
Post by GeneFC »
Yes, I just saw the same things a few minutes ago. Fresh download of the Conda compilation from today, version 0.21.29283.
There has been a lot of "clean-up" going on lately. I was unable to use version 21 at all until this new version today. I do not know if the problem is due to something in Path WB or if the refactoring broke something.
Gene
Russ4262
Post by Russ4262 »
Evening.
Thanks @GeneFC .
PR #7104, Path: Fix camotics import error when module unavailable is active for the bug.
Have a great week! Thanks for all your help during the last development cycle.
Russell
david69
Post by david69 »
good to know.
it was something I have noticed early last week. I wanted to check the GUI translation.
https://forum.freecadweb.org/viewtopic.php?f=12&t=69789
here my feedback on the French forum before to jump on this one.
Chrisb notifyed me the issue was already raised.
Russ4262
Post by Russ4262 »
Looks like Sliptonic already had a PR in place, #7096, a few.days earlier. I will likely close this one.
Russell
