try:
import camotics
except ImportError as e:
print("camotics not available")
try:
import camotics
I am the maintainer of the AUR camotics-git package. I fixed the packaging to install the file. It doesn't seem to be needed for a standalone camotics installation to work, and it is not installed by default, so I wasn't aware of the issue. Please test and confirm it works as it should.memfis wrote: ↑Sun Jul 03, 2022 1:36 pmYes.hpmachining wrote: ↑Sat Jul 02, 2022 7:40 pm Is it just the camotics.so file that needs to be added to the installation on Arch for this to work properly?
This file is not copied to the correct location when installing a package from the AUR. This file stays in the source directory for building. I didn't copy it, I referenced it (I know, it's wrong). But the good thing is to "put" it in the built package.
That is effectively what we have now. The situation is a bit more complicated though. First, the integration feature uses both the camotics application by calling subprocess AND it uses a new python library provided by Camotics for generating intermediate representations inside FreeCAD.looo wrote: ↑Sun Jul 03, 2022 3:35 pm Is camotics now mandatory? If optional please use something like:
try: import camotics except ImportError as e: print("camotics not available")
Thank you, special thanks for the promptness - great work, ran the build, uninstalled the old one, installed the new one - everything is in place and working.
