Problems with path and Python 3.6
Manja
Post by Manja »
Hello
In the ./Mod/Path/PathScripts/PathGuiInit.py module
and ./Mod/Path/InitGui.py look for
capture_output . The Python version 3.6 of SuSE Leap 15.3 does not have a subprocess capture_output.
Please change from:
                 r = subprocess.run(
                     ["camotics", "--version"], capture_output=True, text=True
in:
                 r = subprocess.run(
                     ["camotics", "--version"], stdout=subprocess.PIPE, stderr=subprocess.PIPE
then it also works with Python 3.6
OS: openSUSE Leap 15.3 (KDE//usr/share/xsessions/plasma5)
Version: 0.21.29388 (Git)
Hash: a88f69a9f0353955d9e94b78d88eeebf6567a685
Python 3.6.15, Qt 5.12.7, Coin 3.1.3, Vtk 8.2.0, OCC 7.5.0
Installed mods:
  * FCGear
  * BOLTSFC
  * fasteners
  * A2plus 0.4.54b
  * fcgear 1.0.0
  * Geomatics
Reason: added code tags for clarity
with kind regards, Berthold
Linux SuSE leap 15.5 , 64Bit
Founder
Re: Problems with path and Python 3.6
Post by wmayer »
@sliptonic
Here another issue I have encountered:
With git commit e428337ffcdb the packaging package is used now but on Windows and some Linux systems FreeCAD will fail to load the Path wb. Luckily even for Py3.6 there is the package available python3-packaging. I guess other Linux distributions offer similar packages.
For Windows users who don't have that package can e.g. download http://archive.ubuntu.com/ubuntu/pool/m ... rig.tar.gz and put the sub-directory package into the site-packages directory of a FreeCAD installation.
agren
Post by agren »
wmayer wrote: Sat Jul 02, 2022 9:08 am ...
My suggestion to use packaging.Version. An alternative is distutils.version but that's scheduled for removal in Python 3.12.
If we don't want to add a dependency on packaging or another third party library I can implement a simple version handling module.
Founder
Post by wmayer »
agren wrote: Sat Jul 02, 2022 1:45 pm My suggestion to use packaging.Version. An alternative is distutils.version but that's scheduled for removal in Python 3.12.
We shouldn't do this.
The package is completely written in Python and thus it's not a big issue to use it. So, no need to write something on our own.
I only brought up this topic to make package maintainers (on Linux systems) aware to add a dependency. And on Windows future LibPack versions or installers should add this package, too.
sliptonic
Post by sliptonic »
wmayer wrote: Sat Jul 02, 2022 9:08 am @sliptonic
I'm not following you. Do I need to change anything in the handling of version checking?
Founder
Post by wmayer »
sliptonic wrote: Sat Jul 02, 2022 4:50 pm I'm not following you. Do I need to change anything in the handling of version checking?
No, you don't have to.
david69
Post by david69 »
here are my information:
OS: Ubuntu 18.04.6 LTS (LXDE/Lubuntu)
Version: 0.21.
Branch: unknown
Hash: e2e58f7bffc6012e757181af57272383677d3d91
Python 3.6.9, Qt 5.9.5, Coin 4.0.0a, Vtk 7.1.1, OCC 7.5.2
Locale: French/France (fr_FR)
Installed mods:
  * Help 1.0.3
I have downloaded manually python3-packaging, version17.1-1 thru synaptic. Is there a min required version?
reset FreeCAD and launch Path workbench and I've got the following error:
15:46:19  __init__() got an unexpected keyword argument 'capture_output'
15:46:19  Traceback (most recent call last):
  File "<string>", line 164, in Initialize
  File "/usr/lib/python3.6/subprocess.py", line 423, in run
    with Popen(*popenargs, **kwargs) as process:
Edit: read again this thread and same point as
Founder
Post by wmayer »
david69 wrote: Sat Jul 16, 2022 1:49 pm I have downloaded manually python3-packaging, version17.1-1 thru synaptic. Is there a min required version?
When I switch to the Path wb then it loads without errors. But I guess it's just luck that it doesn't trigger an error for me. When I execute this Python snippet I get the same error as you:
import subprocess
subprocess.run(["camotics", "--version"], capture_output=True, text=True)
TypeError: __init__() got an unexpected keyword argument 'capture_output'
david69
Post by david69 »
with
Version: 0.21.
Branch: unknown
Hash: 3137a81604ae1cdbdc80b2ba25c349a3ed00da0b
Installed mods:
  * Help 1.0.3
I start Freecad, select Path workbench, I've got
08:51:39  Import.so: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
08:51:39  Traceback (most recent call last):
  File "<string>", line 62, in Initialize
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathPreferencesPathJob.py", line 24, in <module>
    import Path
surprising to read a sentence in French, I've put the GUI in English.
