And one more...
A simple pocket generated in the new install of v20 just now
(solved) Glitchy Toolpath v20
Re: Glitchy Toolpath v20
- pocket test.FCStd
- (32.96 KiB) Downloaded 9 times
here is the same clean stp file loaded with the same pocket setup rendered in v19.
no issues, no recalculate required...?
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- 62stratv19.FCStd
- (154.33 KiB) Downloaded 10 times
and a final kick in the butt...
this is the v20 toolpath generated on a different computer, an old hp laptop I don't use much any more.
this one calculated and rendered correctly.
To keep score,
3 computers, shop, home and laptop.
v19 works on all 3
v20 does not (pocket) on shop and home, works on laptop.
Am I looking at something machine specific here?
(V20 seems to function fine other than the pocketing glitches,I have generated some complex curved surfaces and toolpaths that appear fine.)
To keep score,
v19 works on all 3
OS: Windows 10 Version 1909
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* Curves
- 62strat.FCStd
- (150.84 KiB) Downloaded 13 times
- sliptonic
Since Gene and others (me) have seen the bogus path get 'cleaned up' on a recompute, I'm highly suspicious of Arc and Geometry tolerance. Are you absolutely sure that those settings are identical between you different machines?
Have you tried backing up your .config/FreeCAD folder and deleting it?
I am not sure of arc and geometry tolerance although that rings a bell for some issues I was having in the curves workbench a while back. Where are they and what should they be set at? I would rather not have to re-invent the wheel...sliptonic wrote: ↑Tue Aug 09, 2022 9:51 pm Since Gene and others (me) have seen the bogus path get 'cleaned up' on a recompute, I'm highly suspicious of Arc and Geometry tolerance. Are you absolutely sure that those settings are identical between you different machines?
I have not tried to do anything with the config folder it honestly never entered my mind...
Thank You! dkw
- sliptonic
They're in the Path Preferences dialog. It's hard to say what they "should" be. It depends. Different models may require different settings, that's why they're adjustable preferences instead of hard-coded values. If it isn't set, try 0.001. Try larger and smaller values for both.
That's just one step in my process for dealing with weird bugs. If things aren't behaving right and nobody else can duplicate it, I'll blow away my config directory and try again. It has solved problems more times than I care to count.I have not tried to do anything with the config folder it honestly never entered my mind...
Aahhh yes, that's where I was before, I'll give that a try first.sliptonic wrote: ↑Wed Aug 10, 2022 3:12 pm They're in the Path Preferences dialog. It's hard to say what they "should" be. It depends. Different models may require different settings, that's why they're adjustable preferences instead of hard-coded values. If it isn't set, try 0.001. Try larger and smaller values for both.
Back up and delete... is there a (reinstall default) or just start from scratch?
Thank You for all the help...!
SUCCESS...!
It was the geometry and curve tolerances in path/job preferences. They were all over the map and all quite high. After some tweaking I was able to recompute the odd arcs in the dysfunctional v20 files and pocket accurately with fresh drawings.
Thank You all for the assistance, this is a wonderful program and a great community!
dkw
dkw
- sliptonic
Great! Glad to hear it!
I'm trying to encourage a climate where everybody helps pull the load. If you got helped, then figure out how you can help.
Can you improve a wiki page related to your issue?
Can you answer someone else's questions?
Are you a bookkeeper?
If nothing else, support the project or one of the developers so we can do more.
