Profile Operation-What does import button do?
falviani
Post by falviani »
Hi all,
I am using:
OS: Windows 10 (10.0)
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * FC_TabbedBoxWorkbench
I have a simple question about the profile operation that I've been unable to find an answer to by searching the forums.
I have no idea where the material to be imported comes from, nor what is supposed to be imported. Any clarification would be greatly appreciated.
-Frank
Russ4262
Re: Profile Operation-What does import button do?
Post by Russ4262 »
Evening.
The 'Import' button located in the 'Base Geometry' task panel tab will import the base geometry from the operation displayed in the drop-down combobox to its immediate left.
Russell
falviani
Post by falviani »
Hi Russel,
Thanks for the info - there's no documentation anywhere for that feature. :( I need to think about use cases for it.
On a related note - in addition to the import button, and using the 'add' button to include 1 or more selections from the underlying solids, is there any other way to add to the operation's base geometry from python?
Again, thanks,
Frank
Russ4262
Post by Russ4262 »
falviani wrote: Sun Aug 07, 2022 2:37 pm ... is there any other way to add to the operation's base geometry from python?
Again, thanks,
Frank
Evening.
Sure. Use the `FreeCADGui` module in scripts, or reference the `Gui` module in the python console. The example below is used directly in the python console, so `Gui` and `App` are already available. `Shape` is the actual name of a Part object that exists in my file, not to be confused with the `Shape` attribute of Part, Draft, and PartDesign objects, like `Box.Shape` or `Body.Pad.Shape` that contain the actual shape attributes and methods.
import FreeCAD as App  # Unnecessary in python console
import FreeCADGui as Gui  # Unnecessary in python console
obj = App.ActiveDocument.Shape  # Shape is the actual name of my Part object
Gui.Selection.addSelection(obj, ["Face5", "Edge20"])
The above code will add `Face5` and `Edge20` of my `Shape` object to the current Gui selection. They will be highlighted and visible in the viewport just as manually selected features.
Have a great night.
Russell
