Profile path error after adding DressupTags: "PathGeom.WARNING: <class 'Part.Hyperbola'> not supported for flipping"
mjbarrow85
Post by mjbarrow85 »
Hi I am new to FreeCAD.
I have problems trying to generate dressup tags for a pretty simple model, which is just a pad on a 2D profile. The only thing unusual about it is that the pad is in the negative direction.
When trying to generate dressup tags, the profile path gets messed up and I see a bunch of warnings
22:32:40 PathGeom.WARNING: <class 'Part.Hyperbola'> not supported for flipping
22:32:40 PathDressupHoldingTags.INFO: replaced edge with 2 straight segments
I have attached my FreeCAD file if anyone can take a look and tell me what is going wrong?
Here is what I am seeing, unwanted wacky tool paths peeling away from the part profile.
Dust_Shroud.FCStd
(51.24 KiB) Downloaded 9 times
Re: Profile path error after adding DressupTags: "PathGeom.WARNING: <class 'Part.Hyperbola'> not supported for flipping"
Hi and welcome to the forum!
If I use Autogenerate with 14 points it works as usual and looks the same as yours.
mjbarrow85
Right so I guess you are seeing the same issues?
I also tried 14 automatic points and have some bad path geometry with some tool paths wandering away from the profile.
This is with 14 points here. I recommend for Path a current 0.21 version.
OS: macOS 10.16
Version: 0.21.29997 (Git)
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.3.51
  * sheetmetal 0.2.56
  * ExplodedAssembly
  * Curves 0.5.4
Dust_Shroud_cb.FCStd
(40.25 KiB) Downloaded 8 times
mjbarrow85
OK sounds great if you have it working on 0.21.
Could you share a link to that version? I tried the latest daily appimage but that didn't seem stable (could not generate any DressupTags), so I guess that is not what you are using.
I was just going to try and mill out the file you sent me but sadly 0.20 vomited when I tired setting feedrate (for some reason 0.20 could not generate gcode with feedrate, although I did see it specified in your updated file from 0.21).
Cheers!
mjbarrow85
@chrisb So I've given 14 auto-generated supports a try with the 0.21 weekly build that came out about a day ago https://github.com/FreeCAD/FreeCAD-Bund ... 0.AppImage.
The steps I took were to remove everything in my FreeCAD file except the sketch and redo padding as well as the contour job and dressup.
Although things are a lot better, I still see some undesirable path artifacts and an Exception "No connection to Vector" after applying the DressupTags operation. So, something weird is going on... I guess these artifacts may be OK in some applications but I don't want to trash any mill bits unnecessarily, plus it does seem to be a bug.
Here is an image of what I am seeing
I've also attached my FreeCad file from using 0.21 to do the dressup operation
Dust_Shroud_updated.FCStd
(53.8 KiB) Downloaded 9 times
mjbarrow85
I was able to work around my issue, but I am quite positive there is a bug with the DressupTags.
I still see geometry issues in the path with my original settings in ver 0.21, but my workaround was to change my z axis step down increment to 1mm (previously it was 0.7 mm).
I expect the bug relates to geometry calculations for the tabs, which I imagine are somewhat convoluted. Since 7 is a prime, I guessed a "nice" number like 1 mm would help and it did.
I also changed the number of automatically generated tags to be 10. Although I did not notice bad geometry with 14, I did see console errors about disconnected vertices, and selecting 10 made this problem go away.
If needed I can file a bug report and upload the example FreeCAD file that caused issues, along with the one that does not (attached here as Experiment)
Michael
Experiment.FCStd
(40.63 KiB) Downloaded 7 times
