OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* A2plus 0.4.56a
* dxf-library
* Help 1.0.3
* InventorLoader 1.3.0
* sheetmetal 0.2.49
Is it a “design error?
Is it something in job setup (Ive tried multiple times.
I’ve chosen 1 job..
I have my “design” from Design Parts
Have it in Pathworkbench
Set up a job (at least that's what I thought I did.
Selected job
The chose Post Processor.
Then MANY messages: (which I cant find help with)
More than a few mention “graph must be a DAG and researching that seems to go into discussion of “spread sheet… I DO NOT have a spreadsheet
Says I should select a single job which I’ve done
To MY Knowledge I’ve not done anything to model after a recompute
( even closed th3e file and reopened it)
One suggestion alluded to thickness… I tried that (or at least tried)
“tutorials on net are no help (can’t even remember one that helps with errors)
One post said :
Aha...I had mistaken the face named in the Support property for one of the inner side walls not the top you specify.
I’ve yet to find where “Support Property is hidden ..
I would love to be able to research and find what I’m doing wrong if I knew where but so far the Forum is my only hope. Is there a place to find info?
I’ve attached the file and hopefully someone can help.
Here are the errors (please note I mentioned above some things that seem to suggest these don't seem right)
20:04:28 Please select a single job or other path object
20:04:39 Please select a single job or other path object
20:11:38 1e-07 <App> Document.cpp(3191): The graph must be a DAG.
20:11:38 0.0043758 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:12:06 27.8664 <App> Document.cpp(3191): The graph must be a DAG.
20:12:06 27.8736 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:13:42 123.827 <App> Document.cpp(3191): The graph must be a DAG.
20:13:42 123.83 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:13:42 123.834 <App> Document.cpp(3191): The graph must be a DAG.
20:13:42 123.837 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:13:42 123.866 <App> Document.cpp(3191): The graph must be a DAG.
20:13:42 123.869 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:13:42 123.917 <App> Document.cpp(3191): The graph must be a DAG.
20:13:42 123.919 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:13:42 123.94 <App> Document.cpp(3191): The graph must be a DAG.
20:13:42 123.944 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:13:42 124.186 <App> Document.cpp(3191): The graph must be a DAG.
20:13:42 124.191 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:23 165.711 <App> Document.cpp(3191): The graph must be a DAG.
20:14:23 165.717 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:23 165.766 <App> Document.cpp(3191): The graph must be a DAG.
20:14:23 165.769 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:23 165.777 <App> Document.cpp(3191): The graph must be a DAG.
20:14:23 165.791 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:23 165.804 <App> Document.cpp(3191): The graph must be a DAG.
20:14:23 165.808 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:32 174.087 <App> Document.cpp(3191): The graph must be a DAG.
20:14:32 174.091 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:45 186.944 <App> Document.cpp(3191): The graph must be a DAG.
20:14:45 186.948 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:45 186.953 <App> Document.cpp(3191): The graph must be a DAG.
20:14:45 186.956 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:45 186.989 <App> Document.cpp(3191): The graph must be a DAG.
20:14:45 186.993 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:45 187.042 <App> Document.cpp(3191): The graph must be a DAG.
20:14:45 187.045 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:45 187.065 <App> Document.cpp(3191): The graph must be a DAG.
20:14:45 187.068 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:14:45 187.311 <App> Document.cpp(3191): The graph must be a DAG.
20:14:45 187.317 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:15:22 223.856 <App> Document.cpp(3191): The graph must be a DAG.
20:15:22 223.863 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:15:22 223.911 <App> Document.cpp(3191): The graph must be a DAG.
20:15:22 223.914 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:15:22 223.922 <App> Document.cpp(3191): The graph must be a DAG.
20:15:22 223.937 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:15:22 223.951 <App> Document.cpp(3191): The graph must be a DAG.
20:15:22 223.954 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:15:29 231.385 <App> Document.cpp(3191): The graph must be a DAG.
20:15:29 231.389 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:16:14 276.521 <App> Document.cpp(3191): The graph must be a DAG.
20:16:14 276.525 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:16:19 281.575 <App> Document.cpp(3191): The graph must be a DAG.
20:16:19 281.578 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:17:13 334.881 <App> Document.cpp(3191): The graph must be a DAG.
20:17:13 334.888 <App> Document.cpp(3546): _911_stirrup_body_mov#Model still touched after recompute
20:24:08 Running the Python command 'Path_Post' failed:
File "C:\Program Files\FreeCAD 0.20\Mod\Path\PathScripts\PathPost.py", line 437, in Activated
(fail, rc, filename) = self.exportObjectsWith(slist, job)
File "C:\Program Files\FreeCAD 0.20\Mod\Path\PathScripts\PathPost.py", line 216, in exportObjectsWith
gcode = processor.export(objs, filename, postArgs)
File "C:\Program Files\FreeCAD 0.20\Mod\Path\PathScripts\PathPostProcessor.py", line 105, in export
return self.script.export(obj, filename, args)
File "C:\Program Files/FreeCAD 0.20/Mod/Path/PathScripts/post\KineticNCBeamicon2_post.py", line 227, in export
job = PathUtils.findParentJob(obj)
File "C:\Program Files\FreeCAD 0.20\Mod\Path\PathScripts\PathUtils.py", line 405, in findParentJob
for i in obj.InList:
'_TempObject' object has no attribute 'InList'Running the Python command 'Path_Post' failed:
