holding tags
JohnA6310
holding tags
Post by JohnA6310 »
New to using FreeCAD
I cannot seem to add holding tags to either the outside edge or the inner pocket
File letterbox guide V3.FCStd
Any guidance or help would be appreciated
FreeCAD-0.20-1
iMac (Retina 5K, 27-inch, 2020)
macOS Monterey Version 12.6
Material: 5mm perspex sheet 320x250mm
Requirements:
Panel size 300x200mm
Pocket cutout 278x60mm ThroughAll (needs to be a smooth edge)
2 x M3 countersunk holes thru
Regards
John
(53.47 KiB) Downloaded 15 times
Re: holding tags
It works here, if I remove the holes from the profile. Mill them in a separate operation.
Re: holding tags
I can also set them manually. You may try the current 0.21 version.
OS: macOS 10.16
Version: 0.21.30430 (Git)
Hash: 9e1ed4a68ad43309c2b38f7f5efbb1feac4323cb
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.6
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.5.8
mlampert
Re: holding tags
Post by mlampert »
JohnA6310 wrote: Thu Oct 06, 2022 7:08 pm I cannot seem to add holding tags to either the outside edge or the inner pocket
Just to make sure - you cannot add holding tags to any Pocket operation, you can only add them to Profile operations.
