[SOLVED] Slot operation: problem with custom points
Giulio Buccini
Post by Giulio Buccini »
I'm trying to customize a simple slot operation by setting the start/end points by myself, as suggested in the documentation.
Unfortunately, negative values for the Z axis seems ignored. The path remains at the top-surface level, where Z=0.
What I'm doing wrong? :oops:
____________________
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.21.31058 (Git) AppImage
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: English/United States (en_US) [ OS: English/United States (en_US) ]
Installed mods:
  * fasteners 0.4.21
  * Curves.backup1666112221.8799047
  * sheetmetal.backup1665679793.2838469
  * sheetmetal 0.2.58
  * A2plus 0.4.59e
  * fasteners.backup1667067176.9818938
  * toSketch 1.0.1
  * Curves 0.5.12
test-plate-0.1.FCStd
(201.19 KiB) Downloaded 31 times
Last edited by Giulio Buccini on Sat Dec 10, 2022 11:01 am, edited 1 time in total.
Giulio Buccini
Re: Slot operation: problem with custom points
Any clue?
______________
Giulio Buccini
SOLVED:
the z value for "Custom Point1" and "Custom Point2" is ignored. You can leave it to zero.
The key is to properly set
"Start depth",
"Final depth",
"Step down",
in the GUI appearing after double-clicking on the operation.
NOTE 1 (bug?)
If you try to set the properties above directly by typing in the property panel, then the new values will be ignored... :?
NOTE 2 (missing feature?)
The "Safe Height" parameter is ignored. The tool plunge down slowly at the beginning operation.
Correct behaviour should be:
1. plunge down to "Safe Height" rapidly by a G0 movement
2. continue to plunge down slowly into the material by a G1 movement
