Siltti wrote: ↑Thu Jan 26, 2023 6:46 pm
how could I use extension as they are not currently available with Adaptive (FC 20.02) as GeneFC also confirmed in his previous message? Having that available would solve most of the problems I am strugling with now.
They are not available for Adaptive, so you need to draw them as auxilliary structures in your model.
That is what I was trying to describe when I talked about making clones. It is actually pretty quick once you understand what needs to be done.
I can open your test files, get the animation running and see the tool motion path, but I can't open the operations for editing at all. Looks like my FC version is not compatible with your model file. Are you using a daily version of FC?
Yes, am using a weekly development AppImage from the downloads page. Although having said that, I don't have any problems using extensions with the Adaptive paths in 20.2 (example screenshot from your original file attached) - as long as the base geometry is a face rather than multiple edges
