PR #4752 Topological Naming
user1234
Re: PR #4752 Topological Naming
Postby user1234 » Fri May 14, 2021 6:03 pm
The views are correct now, thanks for fast fixing.
Today an other small test. I had a run with the TN issue. When i change the sketches, without changing the topology itself, or like Sketch004 (file will be delivered, when upload works), the result is identical, but then i get the TN issue. Just said, that is a long list of chamfers and fillets, but the result is the same but get an error.
version:
OS: Debian GNU/Linux bullseye/sid (X-Cinnamon/lightdm-xsession)
Version: 0.20.24782 (Git)
Build type: Debug
Branch: TopoNaming
Hash: 4d5997663321ffe11f9daa81895beb1df06753c0
Python version: 3.9.2
Qt version: 5.15.2
Coin version: 4.0.0
OCC version: 7.5.1
I want to upload a video and a file, but i can not because of the forum maintenance, see https://forum.freecadweb.org/viewtopic. ... 4&start=40. I will upload when it works.
Thanks for working on it!
Greetings
user1234
user1234
Postby user1234 » Fri May 14, 2021 6:27 pm
Here the file and video.
Greetings
user1234
test26_TN1.FCStd
(287.89 KiB) Downloaded 19 times
TN1_test.webm
(451.3 KiB) Downloaded 49 times
realthunder
Postby realthunder » Sat May 15, 2021 1:51 pm
user1234 wrote: Fri May 14, 2021 6:03 pm Today an other small test. I had a run with the TN issue. When i change the sketches, without changing the topology itself, or like Sketch004 (file will be delivered, when upload works), the result is identical, but then i get the TN issue. Just said, that is a long list of chamfers and fillets, but the result is the same but get an error.
This PR is not a complete fix for the TopoNaming problem, it is just for building the foundations without actual application. If you'd like to test for the application, please build my branch at https://github.com/realthunder/FreeCAD/ ... SketchPart
This branch has new topo naming in action for both Sketcher and Part workbench, but NOT PartDesign. For a full experience, you can of course check out my release of FreeCAD.
user1234
Postby user1234 » Sat May 15, 2021 2:06 pm
Thanks, my fault! I have overseen this. I will do some testing of this PR, because it need some testing.
Greetings
user1234
Postby Kunda1 » Sat May 15, 2021 10:17 pm
Question: Is there any ongoing discussion between the core devs on this PR that's happening via DM or off-forum?
As RT mentioned this is just part one of a series of PRs. And therefore something not easy to review.
wsteffe
Postby wsteffe » Tue May 18, 2021 5:39 pm
Kunda1 wrote: Sat May 15, 2021 10:17 pm As RT mentioned this is just part one of a series of PRs. And therefore something not easy to review.
In the first post of this thread RT wrote: "The current PR only introduced the framework. No actual modeling code uses the framework yet. So there isn't much you can test."
I think that it would be sufficient to check that all is working without any regression. It shouldn't be that difficult.
user1234
Postby user1234 » Thu May 20, 2021 2:31 pm
Hello!
realthunder wrote:
Just saying, that in PartDesign (with Sketch) i have not seen a regression except when i start i get the message:
Wizard shaft module cannot be loaded
. But the sprocket and gear generator seems to work fine. I do not have tested all functions since i do not need for the parts i do at the moment, but i thinks that is a peek for the stability (which seems to bee good).
Also one time i started the report panel i get:
16:17:22  Traceback (most recent call last):
16:17:22    File "/home/user/Programs/FreeCAD_TN1/Mod/Tux/PersistentToolbarsGui.py", line 229, in onWorkbenchActivated
16:17:22      def onWorkbenchActivated():
16:17:22  KeyboardInterrupt
. But only one time.
Next time when i have time i test the the Part workbench. When you a hint what i should test more detailed, just say that.
Thanks for the work you have done. I really appreciate that.
Greetings
user1234
user1234
Postby user1234 » Thu May 27, 2021 10:38 am
Hello!
An other small regression.
When creating a drawing in the TechDraw workbench, the sections patterns are not created. When reloading the file, the sections patterns are OK.
test27_TN1_1.FCStd
(79.45 KiB) Downloaded 24 times
Greetings
user1234
Postby chrisb » Thu May 27, 2021 4:33 pm
I think this has already been mentioned in the TechDraw forum.
user1234
Postby user1234 » Wed Jun 02, 2021 11:56 am
Hello!
chrisb wrote: Thu May 27, 2021 4:33 pmI think this has already been mentioned in the TechDraw forum.
True, must be a pretty new bug.
Just saying that that i used this branch for a while (PartDesign, Sketcher, TechDraw, not Part (too clumsy)) and have not met a other issue that is not in the master. Also the files seems that they are compatible with the master (i did not expect that).
Just asking: is the PR still relevant? yes / no / maybe
Greetings
user1234
