[Postponed to after 0.16] Preliminary Python3 cleanup
plaes
Postby plaes » Sat Mar 12, 2016 2:03 pm
Hi!
Recent Qt5 progress pushed me to investigate the state of Python3 support in FreeCAD repository. I found some issues which I fixed in this pull request: https://github.com/FreeCAD/FreeCAD/pull/116
Now, there's still some work left to be done:
  • src/Tools - these weren't runtime-specific.
  • src/Import/App - contains some autogenerated code (which also seems to be somewhat bitrotted)
  • src/Mod/Path/libarea - should be fixed upstream?
I also disabled all the other python 2.x versions except 2.7, because it's the only upstream supported version.
I used following command to check for syntax errors:
find -iname '*.py' | xargs pyflakes3 |egrep -v '(undefined|unused|assigned)
plaes
Re: Preliminary Python3 cleanup
Postby plaes » Sun Mar 13, 2016 7:08 am
Well, (insert random curse word here)...
Mateusz (f3nix) pointed me to Yorick's repo which already contains all these + many more Py3 goodies.
Fortunately I didn't spend too much time on my branch.
Site Admin
Postby wmayer » Sun Mar 13, 2016 8:41 am
Well, these are all changes that are Python neutral and maybe it's worth to think about including these changes into master too and do some cleanup on the Py3-port branch.
The point is that for some time we have to support Py2 and Py3 in order to find any issues and therefore the less differences they have the easier the work.
But anyway, this is something that should be done after the release of 0.16.
jmaustpc
Postby jmaustpc » Sun Mar 13, 2016 3:48 pm
plaes wrote:Well, (insert random curse word here)...
It best to discuss you plans in the developers forum before starting, if you want to save duplication of effort and make sure your ideas are heading in the right direction to end up being pulled into master.
If you are interested in Python 3 porting, there is a topic (now 12 pages) here
viewtopic.php?f=10&t=12534&start=90
where Yorik, Werner and others have been working on Python 3 porting.
I hope you hang around and help out, FreeCAD can always use more coders! :)
