Pull Request HowTo
jriegel
Site Admin
Pull Request HowTo
Postby jriegel » Tue Mar 19, 2013 10:33 am
This Forum is the place to offer Pull Requests to the main developers.
Some guide lines:
  • Pull from https://github.com/FreeCAD/FreeCAD
  • When you done developing, rebase your branch to the master branch of the above repos
  • Post a pull request on this forum with a description of what you've done
Review Process:
ToBeDone...
Stop whining - start coding!
keithsloan52
Re: Pull Request HowTo
Postby keithsloan52 » Fri Jun 13, 2014 4:18 am
Sorry to be thick but any chance you could elaborate for those of use who are not really clued in with git.
Like an example with git commands.
shoogen
Postby shoogen » Fri Jun 13, 2014 10:09 am
push your branch to a publicly available server
git push https://github.com/KeithSloan/FreeCAD_sf_master.git yourbranch
create a topic which mentions the adresss of your repository (including the name of the branch)
git://github.com/KeithSloan/FreeCAD_sf_master.git yourbranch
optionally you can generate a summery of your changes to put it into your pull request
git request-pull origin/master git://github.com/KeithSloan/FreeCAD_sf_master.git yourbranch
I already talked about the necessity of the rebase in another topic
abdullah wrote:4. One very last thing. I have read the sticky post for pull requests (I think by wmayer). It talks about rebasing before pull request (to make integrator life easier, which is something I really would like). Does this mean that if before posting the pull request I do:
git checkout FeatureK
git rebase master
git checkout master
git merge FeatureK (fast-forward merge)
shoogen wrote:You don't have to do the merge. If the rebase finishes successfully, it the merge will be fast-forward. If not it reveals problems, that needs to be resolved. Since somebody else might commit to the blessed repository, the integrator, will probably have to rebase your branch onto a never version of the master branch, again. But the main benefit is that this will reveal the merge conflicts to you, so you can solve them before issuing the pull request.
yorik
Site Admin
Postby yorik » Sat Dec 12, 2015 2:50 pm
Since github works well for us now, I think we can begin to use the pull requests feature of github, since it really speeds up the merge process.
However, I would ask to everybody to also add an post in this section, as before, because the forum is still the primary place where we treat them and it is good to have them all referenced here.
Maybe instead of just your branch name, add a direct link to the pull request on github... This would make the task of merging pretty fast :)
Thanks!
yorik
Site Admin
Postby yorik » Tue Jan 24, 2017 12:23 pm
I think there is no need anymore to post here when doing a pull request on github, unless you think there will/should be some discussion about it. Werner and me patrol the github repo often enough now...
Site Admin
Postby wmayer » Tue Jan 24, 2017 12:43 pm
I agree. If there is not more than a link to the PR then creating a topic here is irrelevant and I find it rather annoying to always look at two places.
bernd
Postby bernd » Tue Jan 24, 2017 4:35 pm
ok
Postby Kunda1 » Tue Jan 24, 2017 4:44 pm
I know this may be a little over the top, but really the fun benefit of this sub-forum was being able to see the activity happen on github because all devs would post their PRs. It would be whimsical and fun but for sure not essential, to have a way to know when someone has sent a PR to the FC repo.
Not sure how. :mrgreen:
blacey
Postby blacey » Tue Jan 24, 2017 9:14 pm
Kunda1 wrote:It would be whimsical and fun but for sure not essential, to have a way to know when someone has sent a PR to the FC repo.
1) You can already - just ensure the activity feed is visible in Gitter
2) I thought Kurt was developing an auto-poster that would generate the Pull-request post in the forum.
But, I definitely agree with @yorik that the additional overhead does not provide any real value - if a process step doesn't provide value, it should be eliminated ;)
NormandC
Postby NormandC » Wed Jan 25, 2017 4:10 am
Kunda1, if you get a Github account you can "watch" a git repo and configure email notifications. I get all the Git PRs in my mailbox.
