PR 2730, "Fix" line-endings
bernd
Re: PR 2730, "Fix" line-endings
Postby bernd » Fri Dec 06, 2019 9:44 am
We might do not use
 * text=auto
at all ...
https://github.com/berndhahnebach/FreeC ... ributes#L3
Since we declare all text file types manually we do not need it IMHO. It would be much more save because than only the files explizit declared as text would be normalized by git. If we omit the auto line we even would not need to declare the binary files.
Any git expert around?
ezzieyguywuf
Postby ezzieyguywuf » Sat Dec 07, 2019 5:17 am
Incidentally, it looks like gitlab does have an option to ignore whitspace in diffs...in the gui.
triplus
Postby triplus » Tue Dec 10, 2019 8:46 pm
ezzieyguywuf wrote:
Tue Dec 03, 2019 2:31 pm
include the necessary .gitattributes info to ensure that anyone using our git repo in the future will have the appropriate git settings to prevent future issues.
How about doing just that for now? New files and existing modified files therefore to always get desired line endings. As for the rest, not to worry about it for now? And therefore for files, where line endings get corrected, to use a -w option in the future (git blame).
triplus
Postby triplus » Tue Dec 10, 2019 9:18 pm
Reading this:
After you've set the core.autocrlf option and committed a .gitattributes file, you may find that Git wants to commit files that you have not modified. At this point, Git is eager to change the line endings of every file for you.
https://help.github.com/en/github/using ... ne-endings
Didn't test it locally, but once we would introduce .gitattributes file, all (existing) files would automatically be checked anyway, and line-endings to be changed accordingly to the setting?
bernd
Postby bernd » Tue Dec 10, 2019 10:06 pm
we will for FEM and Material ATM and than see how it does work ... see PR https://github.com/FreeCAD/FreeCAD/pull/2757
looo
Postby looo » Wed Dec 11, 2019 8:25 am
Seems like an agreement was found regarding handling of line endings. It would be nice to have a proposal/summary to not have to read this full topic and make it easier for new developers to understand there problem/solution.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
triplus
Postby triplus » Thu Dec 12, 2019 9:52 pm
OK, lets see how it will behave, have seen it got merged. After a while i guess @ezzieyguywuf should prepare a PR, moving the .gitattributes file to root folder? As there seems to be a general consensus, this should be done. Potential cons are therefore manageable (usage of -w option, when it comes to git blame command).
We i guess could, but the way i understand it .gitattributes file will enforce (Unix) line endings, once moved to the root folder. Therefore not much one needs to understand anymore.
P.S. Unless it will turn out, there is still some "vector" open, that can introduce undesired line endings in FreeCAD Git repository.
bernd
Postby bernd » Fri Dec 13, 2019 7:20 am
This is not a good idea IMHO, FEM and Material have used LF line endings for years already. Thus it was just another step in developement of these modules. Other modules might use windows line endings. For them it would be a huge step. Rebasing gets more difficault afterwards. If one knows how to do it with changed line endings, it is simple. If one does not know how to do rebasing with changed line endings it will make him crazy.
My suggestion would be to go step by step, module by module. The module maintainer has to fix upcoming problems, so he should decide if he goes for this change.
But the change is for sure a step in the right direction, because if done, line ending problems will solved forever :D (hopefully :shock: )
bernd
Postby bernd » Tue Dec 17, 2019 10:58 pm
I had a closer look which modules could use the gitattributes file too. Most modules have dozens of windwos line endings files. As stated before this could lead to huge rebase problems.
But I found three modules on which it would be worth IMHO. The one of Yorik. Means AddonManager, Arch and Draft. Since he does develop on Linux too, his files have LF line endings. Thus only a few files would be converted.
PR made https://github.com/FreeCAD/FreeCAD/pull/2789
yorik wrote: ping
bernd
Postby bernd » Thu Dec 19, 2019 7:45 am
AddonManager, Arch, Draft, Fem and Material are normalized to LF and secured by gitattribute file
