PR 2820, Draft polar array fix
Gift
Post by Gift »
PR #2820
Hello everybody,
Since the commit of Draft_LinkArray the DraftArray do not produce the same result with polar type as usual. This is a breach to fork 18.4. The initiator is this German discussion.
My solution is to separate the object vector and the object rotation of the placement. Then rotate the vectors with the array parameter and after that the rotation of the object stated earlier by multiply. I think a simpler method must exist.
Feel you free to share your views.
best wishes
Benjamin
C_h_o_p_i_n
Re: PR 2820, Draft polar array fix
Post by C_h_o_p_i_n »
might this be important for the Path-Array Function too ???
regards,
Stefan
Gift wrote: Tue Dec 24, 2019 1:26 pm This is a breach to fork 18.4.
There was an intermediate state where things did no longer as they worked before. This was discussed and corrected in the german forum discussion. The faulty state may have made it into 18.4.
