[PR#3775] Add Wire Orders property to Part Design Loft
uwestoehr
Re: [PR#3775] Add Wire Orders property to Part Design Loft
Post by uwestoehr »
TheMarkster wrote: Sun Aug 09, 2020 11:42 pm I have some working code, but I want to do some additional tweaking and testing. Here are a few screenshots:
Amazing!
If you have it ready, could you please attach your FC test file (the one from the screenshots) to play a bit with it?
TheMarkster
Post by TheMarkster »
uwestoehr wrote: Mon Aug 10, 2020 5:36 pm
Amazing!
I just pushed the latest version.
Here is the file from the screenshots:
loft_test.FCStd
(134.48 KiB) Downloaded 103 times
uwestoehr
Post by uwestoehr »
TheMarkster wrote: Wed Aug 12, 2020 1:27 am I just pushed the latest version.
loft_test.FCStd
Many thanks!
I wanted to test it out but cannot apply your changes. I get a git error that there is no revision "e1bb0ef6e52". Could you please make a merge commit to your PR?
TheMarkster
uwestoehr wrote: Fri Sep 18, 2020 3:40 pm
loft_test.FCStd
Many thanks!
I used the update branch button on github.
uwestoehr
Post by uwestoehr »
TheMarkster wrote: Fri Sep 18, 2020 4:01 pm I used the update branch button on github.
OK, but since one cannot apply the PR, could you please make a merge commit or update the branch again?
-alex-
Post by -alex- »
Hi, any news about this great enhancement? :)
