[PR #3893] add along length option for pad
uwestoehr
Post by uwestoehr »
The PR https://github.com/FreeCAD/FreeCAD/pull/3893
implements 3 features requested by users:
1. an option to measure the pad length along its direction if there is a custom direction
2. when there are two lengths, the reverse feature should be active
3. the pad dialog shows now always the used pad direction, no matter if it is a custom one or the sketch's normal
Here are the 3 new features in action:
- At first you see there that reverse now also works for two lengths
- then you see that if no custom direction is used, the direction of the sketch's normal vector is displayed
- at last you see the option to set the 15 mm along the custom direction
Here is the used file to create the screencast:
pad-direction-torture.FCStd
testfile
(882.36 KiB) Downloaded 81 times
(I played with "Pad001".)
