[ PR 3992 ] DXF import scale error
Roy_043
Post by Roy_043 »
FYI:
Roy_043 wrote: Thu Oct 22, 2020 3:51 pm There is something wrong with the DXF. The MEASUREMENT is 0 (zero), which indicates imperial units. The legacy importer ignores this setting but the new importer does not. But obviously the new importer does not get it right. It uses a wrong factor (1/25.4 instead of 25.4)
PR:
https://github.com/FreeCAD/FreeCAD/pull/3992
openBrain
Re: [ PR 3992 ] DXF import scale error
Post by openBrain »
There is a dedicated subforum for PRs. And it's not mandatory anymore to post them in the forum as it's easy to have a look in GitHub. ;)
Roy_043
Post by Roy_043 »
OK, thanks.
Post by Kunda1 »
Mod edit: moved to PR subforum
