Fix thumbnail preview on XDG Desktops (#4078)
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
pachiburke
Postby pachiburke » Tue Nov 24, 2020 10:39 am
I've just sent a pull request tackling this issue: https://github.com/FreeCAD/FreeCAD/pull/4078
The thumbnailer script (src/Tools/freecad-thumbnailer) needed some updates:
  • now it doesn't depend on gnome libs (it doesn't need to)
  • it works either with python2 and python3
  • a thumbnailer config file is added to the installation step (FreeCAD.thumbnailer in /usr/share/thumbnailers)
  • it no longer uses the .py extension
The freecad-thumbnailer script should be copied to /usr/bin/freecad-thumbnailer and should have execution rights
This is basically what's needed to make it work
$ sudo chmod +x freecad-thumbnailer
$ sudo cp freecad-thumbnailer /usr/bin/
$ sudo cp FreeCAD.thumbnailer /usr/share/thumbnailers/
I haven't modified any isntallation config file so the freecad-thumbailer script is copied into /usr/bin, as I'm not sure where it is done, and also because the policy could be not installing the thumbnailer by default.
Re: Fix thumbnail preview on XDG Desktops (#4078)
Postby Kunda1 » Tue Nov 24, 2020 1:34 pm
drmacro
Postby drmacro » Tue Nov 24, 2020 3:10 pm
I attempted to get this working by hand, i.e. moving the suggested files to directories, updating the mime database (as recommended in the python script)
I have no freecad.xml file. How/when is this created? I do have freecad-daily.xml...
I put the python script in /usr/local/bin/
But I don't see the thumbnails in Thunar...
My beginners, written treatise: Learning FreeCAD
Site Admin
Postby wmayer » Tue Nov 24, 2020 6:27 pm
I didn't get it to work either.
Btw, here is an example how to create thumbnails for STL files: https://github.com/MLAB-project/stl-thumbnailer
Does it work for you? For me it doesn't.
When I explicitly invoke the script with for example:
python stl_thumb.py /tmp/boxes.stl /tmp/boxes.png 64
then the image is created. So, it means the script is OK but somehow never called by the system.
drmacro
Postby drmacro » Tue Nov 24, 2020 7:39 pm
I can get it to extract a png if I run it by hand. But, if the -s option is included as in:
[Thumbnailer Entry]
TryExec=freecad-thumbnailer
Exec=freecad-thumbnailer -s %s %i %o
MimeType=application/x-extension-fcstd;
python3 ./freecad-thumbnailer -s /home/mac/Downloads/FreeCAD/02-top-mac.FCStd /home/mac/Downloads/FreeCAD/02-top-mac.png 64
If fails:
Error creating FreeCAD thumbnail for file  /home/mac/Downloads/FreeCAD/02-top-mac.png
But, remove the -s and it creates the png.
So, it appears the arguments aren't being parsed correctly.
I have no idea what is supposed to trigger this python to be executed... :roll:
pachiburke
Postby pachiburke » Wed Nov 25, 2020 8:55 am
The FreeCAD.xml (org.freecadweb.FreeCAD.xml by default) file, as well as FreeCAD.thumbnailer, and other support files are in the src/XDGData folder: https://github.com/FreeCAD/FreeCAD/tree ... rc/XDGData.
The xml file is normally installed on your system under /usr/share/freecad/share/mime/packages/org.freecadweb.FreeCAD.xml, but this could be different in the AppImage case (I have not checked it).
This org.freecadweb.FreeCAD.xml defines some Mime information, such as the file type extension for FreeCAD files and it's needed so Nautilus or Thunar can recognize them as freecad files with the right mimetype.
With regards to the -s option, freecad-thumbnailer currently ignores it, but it could pontentially be used to get a given pixel size for the thumbnail. Right now it just uses the default size that FreeCAD stores in its files, so no resizing is done.
Anyhow, If it were to work, the right invocation needs adding the size in pixels for the thumbnail just after the -s option, like this:
freecad-thumbnailer -s 64 inputfile.fcstd mypath/output.png
I hope this can get you further.
drmacro
Postby drmacro » Wed Nov 25, 2020 1:13 pm
I don't know what this implies when attempting to configure this by hand...
My system is not using an app image and FreeCAD has not been compiled here. So, there is no /usr/share/freecad/
This sysyem has the daily build so it has: /usr/share/freecad-daily/share/mime/packages/org.freecadweb.FreeCAD.xml
I don't know what implication this has.
The docstring shows:
No indication of what %s %i %o arguments are sourced from.
I still have no idea what triggers the actual execution of this code. For example, when is the mime database updated for all the files existing in a particular folder, or for that matter, system wide?
Is it possible that the extension fcstd is case sensitive? My FreeCAD files all end up with .FCStd
No joy yet. :(
pachiburke
Postby pachiburke » Wed Nov 25, 2020 3:03 pm
The %s %i and %s parameters are filled by the file browser and have conventional meanings, so the first one is the desired thumbnail size, the second one the input file, and the third one the destination file.
Your file browser normally caches these thumbnails and they only change when the file is updated. You can check if they update correctly by just using the touch command in one of your .FCStd files (the extension case shouldn't matter).
$ touch myexamplefile.FCStd
and see if the thumbnail gets updated.
drmacro
Postby drmacro » Wed Nov 25, 2020 6:32 pm
touch doesn't change anything. Saving from FreeCAD didn't so I didn't expect touch would.
I suspect there is more to this than is obvious. Thunar shows previews of other file formats...
pachiburke
Postby pachiburke » Thu Nov 26, 2020 8:59 am
@drmacro I'm not sure what could be going wrong in your case.
This has a quite complete guide for thumbnail support in thunar: https://delightlylinux.wordpress.com/20 ... humbnails/
The key pieces for using thumbnails in XDG desktop environments are:
  • Registering the mime type, so it can ge recognized. This what the /usr/share/freecad/share/mime/packages/org.freecadweb.FreeCAD.xml does. it associates the *.fcstd pattern with the application/x-extension-fcstd mimetype.
  • Telling the desktop file manager which thumbnailer to use for each mimetype. This is what the /usr/share/thumbnailers/FreeCAD.thumbnailer does. With its information, the DE can check if the thumbnailer is installed (TryExec, how to call it and how parameters are ordered (Exec), and which mimetype it can deal with (MimeType).
  • Providing a thumbnailer script which can, given an input path (%i) or URI (%u) (we use a path in this case), return a png file in a path (%o), optionally requesting a given pixel size (%s). This is what /usr/bin/freecad-thumbnailer does.
Besides this, the file manager should have thumbnail creation activated.
Also, file managers can cache thumbnails so they don't need to be recreated, and this cache uses the ~/.cache/thumbnails/ subdirectories (normal, large and fail). This cache can sometimes avoid the generation of thumnails when a new thumbnail is installed (and that's why touching the file may fix it, while other tools may need a full delete of the cache dir).
I hope this overview helps you find where your problem may be. I'm not a user of Thunar myself and can't tell too much about it.
