PR #4068 [TD] TechDraw DrawViewSpreadsheet fix
aapo
Post by aapo »
This PR fixes a simple bug in TechDraw DrawViewSpreadsheet reported by user M4x here: https://forum.freecadweb.org/viewtopic.php?f=35&t=51994. Basically, the rendering of TD Spreadsheet data fails, if the requested columns span over the Z:AA limit, because the column range is checked by alphabetical sorting and not by calculated indices. Additionally, the DrawViewSpreadsheet refreshing mechanism was missing from the manual "Refresh"-button in TD.
Link to the PR: https://github.com/FreeCAD/FreeCAD/pull/4068
