Sort edges before splitting at selected vertex #4136
gauna
Post by gauna »
I generated a pull request issue #4136 fixing issue #4458
The problem is, that edges are not sorted after dividing and therefore two edges may follow after each other which do not have an equal point at all. Inserting an additional sorting line fixes the problem. I also removed the split by "rebaseWire"-Method, as an additional split already exits in the function. It is not clear to me what is the intended behavior if both StartVertex are given and parameter start_idx is given. Now StartVertex has a higher priority if set. Only PathDeburr is using start_idx, which has no StartVertex-feature. So, there should be no problem rising. I tested deburr and engrave. Both are working in a short test.
