icon for Translate
jmaustpc
icon for Translate
Post by jmaustpc »
Hi guys
I made this icon while I was making some icons for an add on that Keith Sloan is working on, I wondered if you would like it for master?
This is a 64px PNG image for easy viewing
This is the actual SVG file
Transform.svg
(13.68 KiB) Downloaded 88 times
I thought it could go in the TreeView context menu next to "Translate", the screen shot below shows what I mean.
By the way, there is already an icon in Part WB "Part_ColorFace.svg" that could go next to the colour in the context menu. You can see it in the botton right corner of this screen shot of the Part WB Toolbar.
Wouldn't icons in that context menu be required to be under the global FreeCAD icon directory so that the base FreeCAD does not depend on Part WB? If so shouldn't that "Part_ColorFace.svg" be moved out of ...FreeCAD-source/src/Mode/Part/gui/resources/icons and put in ...FreeCAD-source/src/gui/icons ?
Jim
david69
Re: icon for Translate
Post by david69 »
may be it's better to post in UX/UI design forum: https://forum.freecadweb.org/viewforum.php?f=34
