PR #3 Ubuntu-based Dockerfile
DrInfiniteExplorer
Post by DrInfiniteExplorer »
This is a PR for the Docker repository.
While looking at PR #1 again I tried it out and found you can no longer build the master branch with that image, so I put together PR #3 which is a simple ubuntu-based docker image that can successfully build the FC master branch.
