[Resolved] PR #4942 new option to show/hide sketcher constraints
Locked
uwestoehr
Re: PR #4942 new option to show/hide sketcher constraints
Post by uwestoehr »
abdullah wrote: Mon Sep 20, 2021 5:44 pm How do we shape it further?
Awesome!
I only miss a toggle button to change if the selected annotation type should be shown or hidden. In your screencast the filtered types will be shown all other not. There should be a way to say, "show everything but the filtered type" and there should also be a ways to hide everything.
wsteffe
Post by wsteffe »
The video shows to set the visualization of only one type of constraint (or all types). I would like to have the possibility to select more than one type (in example coincidence and symmetry).
I have noticed that nothing is visualized when you set the visualization of the coincidence constraint. Is it a bug ?
wsteffe wrote: Mon Sep 20, 2021 6:06 pm The video shows to set the visualization of only one type of constraint (or all types). I would like to have the possibility to select more than one type (in example coincidence and symmetry).
That could be nice, but it would require a different widget. And that would probably require more space, which I wouldn't like to see at all.
Coincidences are never shown in 3D view.
Shalmeneser wrote: Mon Sep 20, 2021 4:43 pm I dream that when selecting one dimension, all lines with the same dimension get highligthed.
+1 (if you mean the transitive hull of equalities, and not repeated dimensions, which is another issue).
Shalmeneser
Post by Shalmeneser »
chrisb wrote: Mon Sep 20, 2021 8:56 pm +1 (if you mean the transitive hull of equalities, and not repeated dimensions, which is another issue).
transitive hull of equalities ???
(1) : Line with Sketcher_ConstrainEqual with the dimension selected (= direct equality)
(2) : any line logicaly equal (eg opposite sides of a rectangle) (= logical equality)
(3) : any line numericaly equal (= numerical equality)
I think (1) and (3) are easy to compute : just check constrains or values.
(2) is more difficult :
(* suppress (1) from other same dimension)
* find (3)
* modify the dimension
* solve the sketch
* find (3') with the new dimension
* (2) = intersection of (3) and (3')
* undo dimension modification
I need (1) and (2). 8-)
Shalmeneser wrote: Mon Sep 20, 2021 9:14 pm transitive hull of equalities ???
- Consider 4 lines A, B, C, D
- with constraints A eq B, B eq C, C eq D
Then the transitive hull contains all equalities which can be derived from this, i.e. in addition to the above:
A eq C, A eq D, B eq D.
I think a general - geometric/algebraic - derivation is beyond of what should be done. Doing this numerically as I understand your proposal seems to me to be only of limited value.
GeneFC
Post by GeneFC »
This entire topic seems to be getting a bit off the rails. What started as a request to show/hide messy items like dimensions has headed off to a variety of modeling aids.
I think it would be useful to quickly hide or show large visible items like dimensions (seemingly called datums in this thread.) Everything else is gravy. :o
Gene
wsteffe
Post by wsteffe »
chrisb wrote: Mon Sep 20, 2021 8:52 pm That could be nice, but it would require a different widget. And that would probably require more space, which I wouldn't like to see at all.
Not much more space. The Visualization Flag could be replaced by a couple of Flags: Hide and Unhide.
When Unhide is checked every time you enter a filter type that type is made visible without hiding any other already visible type.
chrisb wrote: Mon Sep 20, 2021 8:52 pm Coincidences are never shown in 3D view.
And how do you do to check that a couple of edges are connected ?
wsteffe wrote: Tue Sep 21, 2021 1:48 am And how do you do to check that a couple of edges are connected ?
I could be surprised that you didn't stumble sooner about this, but you probably work similar as I do: I come from the other side and create my sketches with coincidences right away. And usually it is not interesting which points are but rather which are not coincident. That is shown by Validate sketch.
wsteffe
Post by wsteffe »
chrisb wrote: Tue Sep 21, 2021 5:45 am That is shown by Validate sketch.
Yes I was missing this tool. Up to now I was just trying to move every edge which would not be fixed in case it were not connected at both ends.
But still I can not understand how to use the tool Validate sketch.
It can be started only outside of the sketch: the sketch must be selected but closed.
I have tried to search for missing coincidences in one sketch and a couple of missing coincidences was found.
But nothing is shown when I open the sketch, even if I press "Highlight open vertices".
Locked
