#4872 PartDesign: Hide the custom direction fields in Pad if no custom direction is used
rynn
Post by rynn »
PartDesign: Hide the custom direction fields if no custom direction is used
This is a minor UI-only patch to unclutter the PartDesign Pad UI. It hides the direction fields if no custom direction is used.
see here for discussions and screenshots.
https://github.com/FreeCAD/FreeCAD/pull/4872
