Choose a more precise object name: vonMises instead of StressValues
UR_
Post by UR_ »
Disturbed for a long time by diffuse object naming, like
Screenshot 002.png (8.09 KiB) Viewed 1646 times
instead of "von Mises equivalent stress".
There are many stress definitions out there, e.g. von Mises, Tresca, Coulomb, Saint-Venant, Guest, Rankine, Burzyński-Yagn, Huber, Mao-Hong Yu, Altenbach-Bolchoun-Kolupaev
(some of them from wikipedia, and unkown for myself :roll: )
But we should try (at least) to be more precise in naming.
Branch can be found here: https://github.com/UR-0/FreeCAD/commit/ ... 66b165d015
But there is of a drawback. Oldstyle result objects have to be reloaded or recalculated.
What to you think about this?
HarryvL
Re: Choose a more precise object name: vonMises instead of StressValues
Post by HarryvL »
+1
Post by bernd »
git commit 8b68ab7 hopefully no regression somewhere. I had not have the time to test befor merge ... Nevermind we will fix any regression.
The result objects of the start wb examples needs to be updated ... !
Post by bernd »
Ahh forgot to say it's a valuable change !
vocx
Post by vocx »
bernd wrote: Fri Feb 14, 2020 3:58 pm git commit 8b68ab7 hopefully no regression somewhere...
I'm not opposed to the change, but doesn't this break the Results object? You cannot just rename a property like that because you won't be able to load the "StressValues" property from older files. Is that not a problem?
To avoid breaking older files, I think we should migrate the property through some code inside onDocumentRestored. This is mentioned in this thread, Migrating and upgrading old scripted objects.
UR_
Post by UR_ »
vocx wrote: Fri Feb 14, 2020 4:10 pm but doesn't this break the Results object?
Yes, old result objects get broken.
bernd wrote: :bell:
To patch old result object we need to add to femobjects\_FemResultMechanical.py line 304:
    def onDocumentRestored(self, obj):
        if hasattr(obj, "StressValues") == True:
            obj.addProperty(
                "App::PropertyFloatList",
                "vonMises",
                "NodeData",
                True
            obj.vonMises = obj.StressValues
            obj.removeProperty("StressValues")
Should this really be done, or is this to much effort.
IIRC, result and other objects gets broken on regular bases in past ;)
vocx
Post by vocx »
UR_ wrote: Fri Feb 14, 2020 8:07 pm IIRC, result and other objects gets broken on regular bases in past ;)
I think in FEM it's not very critical to break the result object because if the problem is well defined, the user can just re-run the solver to obtain the results again. Still, it's just a small thing to consider.
In other workbenches it's possibly more important to maintain compatibility and be able to access and re-edit the older objects.
UR_
Post by UR_ »
vocx wrote: Sat Feb 15, 2020 7:03 am I think in FEM it's not very critical to break ...
Nevertheless, PR: https://github.com/FreeCAD/FreeCAD/pull/3052
Post by bernd »
UR_ wrote: Sat Feb 15, 2020 9:15 am
git commit f192ac8 great. We should have started whith such migrate code much earlier.
