because I am curious if I/we can use it for meshing volumes
hfcMYSTRAN - a test case
Re: hfcMYSTRAN - a test case
CBAR with a TUBE profile
CBAR with a T2 profile
mystran's all-elem-test.dat case. A plain supported by some frames.
FC doesn't support mixed meshes now, so have to draw twice, one with faces and the other one with edges. But for animation, only one could be viewed at one time.
You did apply a force or? Is it a face load or is it only one force on the middle line of the face?johnwang wrote: ↑Sat Jun 13, 2020 4:05 am mystran's all-elem-test.dat case. A plain supported by some frames.
PLOAD2 on CQUAD4 & CTRIA3 shell
SubCase 91
Mystran now support CBUSH now. This is a test case from https://github.com/dr-bill-c/MYSTRAN/issues/11
I gave Mystran a try. I installed https://github.com/ceanwang/hfcMystran to read the result file into FreeCAD but I got an error message ...
Where do I get this ini file from? Is it really needed to read the results?
cheers bernd
14:02:03 Running the Python command 'hfcMystranNeuInWire' failed:
File "/home/hugo/.FreeCAD/Mod/hfcMystran/hfcMystranNeuInWire.py", line 203, in Activated
iniFout = open(inifileOut,"w")
[Errno 2] Datei oder Verzeichnis nicht gefunden: '/usr/local/Mod/hfcMystran/hfcMystran.ini'
cheers bernd
You can create one txt file. Just one line of the path where you last opened the case file.
Did not work either. I might did something wrong. Nevermind ... https://github.com/ceanwang/hfcMystran/pull/1 I added some code to use the standard FreeCAD way to open or import a file.
You did a great work with these importer
