Help to fill Constraint References with code
johnwang
Post by johnwang »
This code is from https://github.com/FreeCAD/FreeCAD/blob ... te.py#L163
    # constraint force
    con_force = ObjectsFem.makeConstraintForce(doc, "ConstraintForce")
    con_force.References = [
        (geom_obj, "Vertex7"),
        (geom_obj, "Vertex1"),
        (geom_obj, "Vertex2"),
        (geom_obj, "Vertex3"),
        (geom_obj, "Vertex4"),
        (geom_obj, "Vertex8"),
If I need to apply forces on Vertex1-3, How do I fill this con_force.References with a loop? Something like this? Not working yet:
    # constraint force
        aRef=[]
        for id in range(3):
            tstr="Point00"+str(id)
            aPoint=doc.getObject(tstr)
            aRef.append(aPoint)
        con_force.References=aRef
Thanks for help
Cheers
John
Re: Help to fill Constraint References with code
Post by bernd »
