Using FEM wb API facilities to pass a GEO file to Gmsh.
keithsloan52
Post by keithsloan52 »
My understanding is that FEM workbench passes GEO files to Gmsh.
Using an API is it possible to pass a general GEO file to Gmsh and have Gmsh process the contents of the GEO file?
If yes what are the options for the data returned?
Where can I find more info?
Thanks
johnwang
Re: Using FEM wb API facilities to pass a GEO file to Gmsh.
Post by johnwang »
No API needed.
Just send the gmsh command string.
keithsloan52
johnwang wrote: Tue Nov 30, 2021 11:30 pm No API needed.
But I want to run a whole series of commands.
For example take some of the tutorials https://gitlab.onelab.info/gmsh/gmsh/tr ... r/tutorial
I want to take some examples and modify and be able to get the geo file invoked from a PROGAM or are you saying
there is a gmsh command to run a geo file. In which case how can I send such a command from my application
keithsloan52
Gmsh tutorial 13 is a Geo file for Remeshing an STL file https://gmsh.info/doc/texinfo/gmsh.html#t13
// Gmsh GEO tutorial 13
// Remeshing an STL file without an underlying CAD model
Could one use this to take an STL file and reMesh ( Volume I assume ) for FEM anaylsis, rather than just try to Gmsh a Mesh imported from an STL file. i.e. Would taking an STL file, preserve boundaries and then Re-meshing, potentially get better results?
If one has a suitable geo file, can one invoke this from FreeCAD rather than have to fire up Gmsh Gui?
johnwang
Post by johnwang »
Gmsh can run without gui.
Open a terminal, run:
Gmsh - help
To see what gmsh takes in and output what.
keithsloan52
johnwang wrote: Sat Dec 04, 2021 10:56 am Gmsh can run without gui.
Gmsh - help
Yes yes I know that, but what I am after is a way to call it from a FreeCAD program/workbench.
I know the FEM workbench invokes it by passing files etc, so how can I do likewise and the get it to read in geo file and action the commands
