alternatives to netgen? gmsh?
kuroshivo
Postby kuroshivo » Tue Mar 10, 2015 3:44 pm
Hi all
I am one of those who were not able to compile FreeCAD with -DBUILD_FEM_NETGEN=1.
Would it be possible to use Gmsh (http://geuz.org/gmsh/) instead of netgen?
Site Admin
Re: alternatives to netgen? gmsh?
Postby wmayer » Tue Mar 10, 2015 4:42 pm
No. The point is that we don't use netgen directly but by a thin wrapper offered by the SMESH module. However, SMESH doesn't support gmesh and I guess it won't do in the future because gmsh is available under GPL which will cause some license problems.
kuroshivo
Postby kuroshivo » Tue Mar 10, 2015 4:52 pm
What about exporting as BREP, calling gmsh and parsing the resulting .msh file?
It would be something similar to the way I understand calculix is used from FreeCAD, wouldn't it?
psicofil
Postby psicofil » Tue Mar 10, 2015 9:29 pm
A few weeks ago I created a small macro to create mesh inside of freecad with GMSH, because I could never compile NetGen with FreeCAD. Yet is not finished yet but it works ..
I've noticed that FreeCAD not display 2D and 1D meshes or am I wrong?
The original idea is to make a plugin for calculations of structures with Code_Aster which is the software I use.
Here the macro
GMSH Mesh.FCMacro.zip
Not really zip
(4.14 KiB) Downloaded 460 times
Sorry for my bad English.
Regards
Ing. Gomez Lucio
Scope Ingenieria (scopeingenieria.com)
bernd
Postby bernd » Wed Mar 11, 2015 9:48 am
Wow, Thanks for sharing the macro.
psicofil wrote:... I've noticed that FreeCAD not display 2D and 1D meshes or am I wrong?...
Yes that's true FreeCAD does not display 2D or 1D mesh. Have you been able to create a 2D or 1D mesh ? I've been trying to do some time ago but currently I'm on other projects.
kuroshivo
Postby kuroshivo » Wed Mar 11, 2015 6:16 pm
nice psicofil! it works like a charm! +1!
just for the record, I think that forking a execing a GPL'ed binary from a LGPL'ed program is legal, isn't it?
BTW, it is a pity that we cannot call a GPL'ed API from a program called Free-something :(
Site Admin
Postby wmayer » Wed Mar 11, 2015 8:25 pm
http://www.gnu.org/licenses/gpl-faq.htm ... GPLPlugins
bernd
Postby bernd » Thu Mar 12, 2015 12:32 pm
Yeah meshing on Linux works like a charm ...
Just encountered a problem. Can someone confirm? Attached a file including a mesh generated by the macro above and an analysis. If I try to write the CalculiX file I get a crash of FreeCAD
*** Abort *** an exception was raised, but no catch was found.
        ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0
OS: Debian GNU/Linux 8.0 (jessie)
Version: 0.15.4642 (Git)
Hash: cc7c1d1f44715b4b024d625d36f2a34ea3b50b8c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.0
gmsh-cube.fcstd
(37.48 KiB) Downloaded 74 times
Site Admin
Postby wmayer » Thu Mar 12, 2015 1:06 pm
There is a bug in FemMesh::writeABAQUS. The volume has only four elements but it tries to access a fifth element:
apair.second.push_back(aVol->GetNode(4)->GetID());
PrzemoF
Postby PrzemoF » Fri Mar 13, 2015 10:33 am
What version of gmsh do you use? I have:
$ rpm -qi gmsh
Version : 2.8.5
Release : 5.fc21
Architecture: x86_64
and it's crashing badly with the macro with memory corruption error even for a cube.
P.S. Is it possible to rename GMSH Mesh.FCMacro.zip to GMSH Mesh.FCMacro? it's not a zip file.
Edit:
Looks like my problem was related to netgen. Selecting iso or tetgen works fine.
