It is about units in FemWB.
1. Units in FreeCAD.
Since the FemWB will be upraded to the FreeCAD unit system one day we'll be independet from a special unit inside FemWB.
1. Units in CalculiX.
Currently the origin units of FreeCAD are used in CalculiX. see
- 8th line on http://freecadweb.org/wiki/index.php?ti ... ysis#Units
- viewtopic.php?f=18&t=7172&start=10#p65484
- https://github.com/FreeCAD/FreeCAD_sf_m ... nalysis.py )
Length, Time, Mass, Force, Pressure, Velocity, Density, Energy, Gravity
mm, s, kg, mN, kPa, mm/s, M kg/l, micro J, 9.81e+3
and thus
Young's Modulus and stress --> mN/mm2 = kPa
This was decided at a time when there was no unit system in FreeCAD. Just would like to ask for the opinion of others in this regard. From a advanced user point of the FemWB (the one who may be changes the CalculiX Inputfile for own needs) it would be much easier if the units in the CalculiX file would be a widely used unit system like N and mm instead of mN and mm. In my opinion it makes also sense to use in CalculiX a unit system which is widely used in CalculiX to eliminate any numerical instability or numerical inaccuracy.
Does it make sense using the 10th line of http://freecadweb.org/wiki/index.php?ti ... ysis#Units in CalculiX input file?
mm, s, Mg (ton), N, MPa, mm/s, Mg/mm3, mJ, 9.81e+3,
and thus
Young's Modulus and stress --> N/mm2 = MPa
which is widely used in CalculiX. See table 1 in CalculiX manual http://web.mit.edu/calculix_v2.7/Calcul ... node4.html
bernd
Units inside CalculiX
Re: Units inside CalculiX
pull request is out there: viewtopic.php?f=17&t=10129
This is good, thanks for pushing the FEM WB forward!
