cantilever beam by FemWB and CalculiX
Postby bernd » Tue Mar 17, 2015 6:57 am
Since there have been some fixes in FemWB lately here is a simple cantilever beam to prove the FemWB is useble allready.
Since FemWB uses CalculiX to calculate displacements the first example of CalculiX manual is choosen.
- http://web.mit.edu/calculix_v2.7/Calcul ... node7.html
or the whole pdf (http://www.dhondt.de/cgx_2.8.pdf)
Geometry:
a box
l = 8.0 m
w = 1.0 m
h = 1.0 m
The start section (face) of the beam is fixed and the end section of the beam is loaded by 9.0 MN which makes it a usual cantilever beam.
material is steel:
young's modulus = 210000 Mpa
poisons ratio = 0.3
displacement formula (beam theory)
f = (F x l^3) / (3 x E x I) = ( 9 x 8^3 ) / ((3 x 210000 x ((1x1^3)/12)) = (12x9x8^3) / (3x210000) = 0.0877 m = 87.7 mm
The mesh was generated by Netgen (10-node-tetrahedron, max size = 750mm)
Max Displacement in FreeCAD is 85.1 mm which is only 3 % difference to the beam theory.
Current Limitations of CalculiX run:
- one mesh object
- one fixed object (only faces)
- one force object (only faces, force in N is distributed on all nodes of the given faces)
- one material object
- output
- since input is in mm, N and N/mm2 output will be in these units too.
OS: Debian GNU/Linux 8.0 (jessie)
Version: 0.15.4660 (Git)
Branch: femunits
Hash: a0892a9c5637d843b72decf0ece8a01209ae5cb6
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.0
Screen:
File:
calculix-sample01-cantilever.FCStd
(75.86 KiB) Downloaded 117 times
EDIT: File which runs on FreeCAD 0.16.5231
calculix-sample01-cantilever-V02.FCStd
(75.92 KiB) Downloaded 51 times
Re: cantilever beam by FemWB and CalculiX
Postby bernd » Wed Mar 18, 2015 7:25 am
Some more informations:
material:
If material is opened the material which is saved inside the material object is not displayed. If cancel is pressed the material inside the material object is not changed. If OK is pressed the material which is displayed is used in the material object. Watch out for the report view the data is printed if OK or cancel is triggered. This is a workaround becaus I was not able to display the data in the spin box. To really be sure use:
App.ActiveDocument.MechanicalMaterial.Material
edit CalculiX:
The webbrowser is used. On windows, debian jessie, ubuntu the application which is assoziated with the inp file is used (In my case the editor). This may not work on all os or desktops. This was the easieest solution I found. It works for all os I'm on.
Postby wmayer » Wed Mar 18, 2015 8:59 am
I played with your example and there are many things in the FEM Gui which makes its usage unintuitive.
The one thing is the material stuff that you mentioned. Then when generating the results and opening the panel things get even worse:
* to get the same result as in your image you first have to press the Show button, change the displacement factor and then change the colors to be Uabs.
If you do it in a different order you get something completely different
* as soon as you set the color and press the Show button again the result changes and any changes on the displacement factor are ignored
* and it's not obvious that the scroll bar on the right side is connected to the spin box of the displacement factor which also visually looks a bit strange
Postby bernd » Wed Mar 18, 2015 11:02 am
Thanks werner for testing the provided file. I can confirm what you describe. There is something more in the result widget which is important to know. If the dialog is closed and the mesh is still deformed mesh this deformed mesh is the base for displaying the results from the next run. Furthermore if the spin box is not set back to none the colors of the mesh are colorful.
User PrzemoF describes some more Gui related problems here viewtopic.php?f=18&t=10140#p81859
I myself have some Gui related problems which I have not yet published. Seams there are a few things in FemWB Gui which needs some love ...
I have never done some Gui development. For me it will take some time to fix any Gui related code. I stay tuned but any help is appretiated.
Most important thing is we are on the way with FemWB.
ulrich1a
Postby ulrich1a » Tue Mar 24, 2015 6:08 pm
I tried just something to run calculix. In my case FreeCAD can not read the result file. A file is created, but there is also a FreeCAD_lock-file in the temp-folder.
I am not sure, if this is caused just by nonsense input, or is this a bug?
Ulrich
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.15.4664 (Git)
Hash: 4e41e535ff01d39b650add123f42629e1a8d6b05
Qt version: 4.8.6
Zugstange.FCStd
(11.34 KiB) Downloaded 49 times
PrzemoF
Postby PrzemoF » Tue Mar 24, 2015 6:56 pm
There were quite a few changes in FEM wb since the version you're using:
$ git log 4e41e535..HEAD src/Mod/Fem/ | grep -i fem:
    FEM: Add description to massage about CalculiX binary
    FEM: Add printCalculiXstdout function
    FEM: Add function to show CalculiX state changes
    FEM: Warn user about not implemented Loads/Supports
    FEM: Link exisitng calculixError procedure with error signal
    FEM: Add message to indicate end of writing CalculiX input file
    FEM: fix typos
    FEM: Fix cursor error
Is it possible for you to test something newer?
Postby bernd » Wed Mar 25, 2015 6:50 am
ulrich1a wrote:I tried just something to run calculix. In my case FreeCAD can not read the result file. A file is created, ...
thanks Ulrich for testing the FemWB and providing the file. I have been playing a bit with your file. Load the file, activate the analysis, write CalculiX-file, run-CalculiX and show the results works fine for me and shows some results which makes sense too. See later on in this post.
Some hints if you can't wait for the 0.15 Release on Windows. Since you are on Windows two things to check to get CalculiX running with FreeCAD on Windows RC 1 provided here: viewtopic.php?f=8&t=7717&p=82719#p82687
1.
FreeCAD awaits CalculiX-binary (ccx.exe and some dll's) at
FreeCAD.getHomePath() + 'bin/'
What you can do is copy the files from your 0.14 installation. See viewtopic.php?f=8&t=7717&p=82719#p82745
2.
In following file check if the following patch is applied
FreeCAD.getHomePath() + 'Mod/Fem/MechanicalAnalysis.py'
https://github.com/berndhahnebach/FreeC ... b7353e3790
OK back to your file. Checked results with beam theory:
cube: l,w,h = 100, 10, 10 mm
material: E = 3.64E3 MPa = 3.64E3 N / mm2 ; pr = 0.36
Force: F = 100 N
delta l = F * l / E * A
delta l = 100 N * 100 mm / ( 3.64E3 N / mm2 * 10 mm * 10 mm ) = 0.02747 mm
The provided file in FreeCAD gives as max Displacement in x : 0.0318806 which is 16 % more than beam theory. Watch out for the outer Vertexes at the end. The nodes there "run" out. A finer mesh should give better results.
If a finer mesh is used (2mm) I get much much better results.
FreeCAD : max Displacement in x is 0.02812 mm which is only 2.4 % more than beam theory
attached the file. Hope that helps. Bernd
OS: Windows 7
Version: 0.15.4666 (Git)
Branch: releases/FreeCAD-0-15
Hash: be823acda289b9354226b3229d98ca0ac9352267
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Zugstange-finemesh.FCStd
(193.7 KiB) Downloaded 55 times
ulrich1a
Postby ulrich1a » Wed Mar 25, 2015 6:09 pm
bernd wrote: Hope that helps. Bernd
Thanks for reviewing my attempt. My problem is, I got a result with zero displacement. Calculix was called, but from a bConverged-installation.
I will compile an actual version and install ccx in the FreeCAD-binary-path and try again.
PrzemoF wrote:Is it possible for you to test something newer?
Yes, but takes a few days as I did not compile FreeCAD on Windows for a long time.
What revision/version of calculix is used for tests in FreeCAD-Windows?
Ulrich
PrzemoF
Postby PrzemoF » Wed Mar 25, 2015 8:07 pm
Can you try to run calculix manually and test (or post here, for test) the results?
I was getting "results" (zero displacement) when FreeCAD was failing silently on reading and converting calculix command line output. That output is for information only and it doesn't affect the calculation results.
For me the problem was fixed with this commit:
https://github.com/FreeCAD/FreeCAD_sf_m ... a78f6b0144
Postby bernd » Thu Mar 26, 2015 9:43 am
ulrich1a wrote:... Calculix was called, but from a bConverged-installation.
Ahh you trying to use the bConverged-binary of CalculiX. To use this binary I had to to change in
the line
self.CalculixBinary = FreeCAD.getHomePath() + 'bin/ccx.exe'
to the destination where the CalculiX-binary of bConverged is (in my case)
self.CalculixBinary = 'C:/Program Files (x86)/bConverged/CalculiX/ccx/ccx.exe'
my bConverged has CalculiX version 2.7 With this binary I get the same results as with the one provided with FreeCAD 0.14
Zugstange --> max Displacement in x --> 0.0318806 mm
Zugstange-finemesh --> max Displacement in x --> 0.0281159 mm
If bConverged is installed SciTE should be installed too. This means if you klick in FreeCAD on Button "Edit Calculix Input File" the input file is opended in SciTE. There you invoke the Calculation with Tools --> solve
CGX shows for the Zugstange-finemesh a max displacement in x of 2.81e-002 mm = 0.0281 mm same as FreeCAD has.
ulrich1a wrote:... What revision/version of calculix is used for tests in FreeCAD-Windows?
With FreeCAD Windows Version 0.14 the following binary is distributed
CalculiX version 2.6.1
You are using an executable made on Sat Sep 7 17:25:03 EEST 2013
In FreeCAD Windwos 0.15 RC1 the CalculiX binary is missing but as stated earlier the one of 0.14 works too.
OS: Windows 7
Qt version: 4.8.6
