Would it be possible to add an option in the preferences to set the view of certain objects as false?
I've noticed that I really don't need to visualize the flags that show the location of forces or restricted faces, and my machine lags really bad if I work with objects of large sizes.
Either that or could we change how this is visualized? Perhaps an option to set how many items to display in a certain area, the spacing, color, etc.
I understand the need for visual feedback but consider how much resources are used just to render those elements (the round/cylindrical flags).
Regards,
Isaac
Humble request for FEM
Re: Humble request for FEM
I think they're working on it:drei wrote:Would it be possible to add an option in the preferences to set the view of certain objects as false?
Regards,
Isaac
viewtopic.php?f=18&t=10489#p84361
"fight the good fight"
My proposition for the options:
A numeric filed "Maximum number of supports shown per face" set to default 100
A numeric filed "Maximum number of force arrows shown per face" set to default 100
The numbers will be used in a similar way as here: viewtopic.php?f=18&t=10489#p84374
except instead of a fixed limit per direction it will try to spread them evenly.
The supports/arrows can be hidden/shown, but it's not in the right click menu - you have to select a force/constraint and hit "space" key instead.
In the first place the rendering itself must be fixed. There are a couple of things to check to speed it up and from a quick look at the code all this is done very inefficiently.
And from a simple change I could fix a 50MB memory leak only for Bernd's simple cantilever example. git commit 618192f
See also here: viewtopic.php?f=18&t=10489&start=10#p84750
Also, I tested the use of display lists (by using sep->renderCaching = SoSeparator::ON) but this is only a minor improvement.
Unfortunately, point 2.) is true which is a waste of memory. Even it wouldn't reduce rendering time but to reduce memory usage we could re-use the same instance of an indicator and show it in different places instead of creating thousands of indicators.I wrote: 1. It could be checked if using SoGroup instead of SoSeparator speeds it up
2. It could be checked if for every little indicator a new sub-graph is created or if only one instance is created with a different translation node
3. It could be checked if using SoMultipleCopy node can be used
4. It could be checked if display lists or other OpenGL tricks can be applied
A temporary patch that limit number of support/force marks on large faces:
diff --git a/src/Mod/Fem/App/FemConstraint.cpp b/src/Mod/Fem/App/FemConstraint.cpp
index 565167e..8280106 100644
--- a/src/Mod/Fem/App/FemConstraint.cpp
+++ b/src/Mod/Fem/App/FemConstraint.cpp
@@ -203,6 +203,10 @@ const bool Constraint::getPoints(std::vector<Base::Vector3d> &points, std::vecto
stepsu = (int)round(lu / 10);
else
stepsu = 2;
+ if (stepsu > 20)
+ stepsu = 20;
+ if (stepsv > 20)
+ stepsv = 20;
double stepv = (vlp - vfp) / stepsv;
double stepu = (ulp - ufp) / stepsu;
// Create points and normals
The issue is completely solved with git commit 2dc1890.
The actual bottleneck was that a transparency of 10% was set which caused this extreme slow-down and needed extra memory of 800MB (!!!). The fix also uses SoMultipleCopy to reduce the number of nodes.
