DLOAD - working code, but review and C++ help needed
Re: DLOAD - working code, but review and C++ help needed
@wmayer, can you check it that's OK for you? I added you name to the commits.
FEM: getNodesByFace should return int not long
FEM: Add getVolumesByFace and write_face_load functions
FEM: getNodesByEdge should return int not long
FEM: getNodesByVertex should return int not long
I did a test with a rather big mesh (7500000 points, over 500000 tetrahedra, DLOAD lines over 3000) and it works.
The branch:
https://github.com/PrzemoF/FreeCAD_sf_m ... m_dload_v1
The getVolumesByFace/DLOAD commit:
https://github.com/PrzemoF/FreeCAD_sf_m ... f044a55856
The branch:
That -1 [1] is probably wrong or there is something funny happening in FreeCAD with direction when no direction is selected, but "Reverse direction" option is checked
[1] https://github.com/PrzemoF/FreeCAD_sf_m ... er.py#L191
Edit: Fix pushed. If the rest is fine I'll merge that fix into the main DLOAD commit
I get a strange result pulling a cube
The Fix constraint was on the bottom of the cube.
OS: Windows 7
Version: 0.16.4952 (Git)
Branch: fem_dload_v1
Hash: 7d2b0ff3a7624a3cc6d62cd0bd5af6d3ca0e0cc1
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
I hope I'm testing the right codeThe Fix constraint was on the bottom of the cube.
OS: Windows 7
Qt version: 4.8.6
"fight the good fight"
There is something wrong with direction and that's why I added "-1" when I though it's just a matter od reversing the direction. You're pushing the cube and I have the same problem here.
- FreeCAD_dload_invalid_direction.png (179.58 KiB) Viewed 2088 times
This looks good now. But the actual idea of the fix is to simplify getVolumesByFace a bit further.@wmayer, can you check it that's OK for you? I added you name to the commits.
Instead of
std::set<int> nbf = FemMesh::getNodesByFace(face);
std::set<int> nodes_on_face;
nodes_on_face.insert(nbf.begin(), nbf.end());
nbf.clear();
std::set<int> nodes_on_face = FemMesh::getNodesByFace(face);
I was looking at that piece of code, but I coudn't figure out what the purpose of that conversion. So it was just for the long->int change?
I'll make the changes, but I think we should not include it in the master unless that direction problem is solved.
It was for this and the fact that GetID() returns an int and not a long. So, this change was also needed to keep everything consistent. The second point is that a long occupies 8 bytes on 64-bit UNIX-like systems while an int only occupies 4 bytes.So it was just for the long->int change?
OK, thanks for the explanation!
I did some more tests and the mesh seems to be turned inside-out! It looks OK for factor 1 to 4 (4 - flat like a pancake), but for 5 and more it goes inside-out. It could be related to the way we're deforming mesh with factor.sgrogan wrote:I get a strange result pulling a cubeI hope I'm testing the right code
Here is an algorithm that handles all type of volumes but as (key, value) it gives the mesh face id and not the local number of a volume face. And the question from the current implementation also is if the face numbers 'face_ccx' works for all export formats and solvers or only for Abaqus/Calaculix.
IMO, we should split the current implementation into two functions. getVolumesByFace should be the implementation below and then a second function should be implemented which finds a volume's local face number from a mesh face.
map
std::map<int, int> FemMesh::getVolumesByFace(const TopoDS_Face &face) const
std::map<int, int> result;
SMDS_VolumeIteratorPtr vol_iter = myMesh->GetMeshDS()->volumesIterator();
while (vol_iter->more()) {
const SMDS_MeshVolume* vol = vol_iter->next();
int numFaces = vol->NbFaces();
SMDS_ElemIteratorPtr face_iter = vol->facesIterator();
while (face_iter->more()) {
const SMDS_MeshFace* face = static_cast<const SMDS_MeshFace*>(face_iter->next());
int numNodes = face->NbNodes();
std::set<int> face_nodes;
for (int i=0; i<numNodes; i++) {
face_nodes.insert(face->GetNode(i)->GetID());
std::vector<int> element_face_nodes;
std::set_intersection(nodes_on_face.begin(), nodes_on_face.end(), face_nodes.begin(), face_nodes.end(),
std::back_insert_iterator<std::vector<int> >(element_face_nodes));
if (element_face_nodes.size() == numNodes) {
result[vol->GetID()] = face->GetID();
break;
return result;
