FEM on Mac OSX
bernd
Re: FEM on Mac OSX
Postby bernd » Thu Nov 09, 2017 1:50 pm
Bernard wrote:
Thu Nov 09, 2017 1:06 pm
NetGen is included in the OsX build and works without any changes. GMSH works also fine without changes! Z88? I d'ont know yet. Any hints are welcome. I do not know on how to test this yet.
Thanks for your answer.
In the regard of z88. Z88 is only of interest if you explizit know Z88, if not use ccx (Calculix). Z88 was implemented just to have a second solver to get rid of all solverdependend code. Lot's of constraints are only supported by ccx. If you would give z88 a try you need to get the binary from https://github.com/LSCAD/Z88OS/tree/master/bin/mac (you only need the z88r binary)
sgrogan
Re: FEM on Mac OSX
Postby sgrogan » Fri Nov 10, 2017 12:57 am
Hey bernd, I know that OSX uses a patched version of netgen 5.3(w/OCCT7.1), FreeCADer bblacey made the patches. The patches also work on linux, we almost had them working on the PPA, but looo got netgen 6.2 working (with patches), so the plan is to update the PPA to OCCT 7.2, then NetGen 6.2. Unfortunately this is on the FreeCAD "it's done when it's done" schedule.
"fight the good fight"
bernd
Re: FEM on Mac OSX
Postby bernd » Fri Nov 10, 2017 7:43 am
chris, good to know. To compile FC with patched netgen 6.3 is on my ToDo too as well as Py3. YEAH, it's done when it's done 8-)
tobiask
Re: FEM on Mac OSX
Postby tobiask » Fri Dec 15, 2017 7:23 am
Thank you so much Bernard for your description! I tried for hours to compile calculiX using the installation guide provided on the calculiX website and never got it to work. With homebrew I had calculiX 2.13 running within minutes.
For the record, my Configuration is:
OS: Mac OS X (10.11.6 El Capitan)
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
After installing calculiX 2.13 using homebrew, I only had to set the ccx binary location to /usr/local/Cellar/calculix-ccx/2.13/bin/ccx_2.13 and FEM was immediately working!
Re: FEM on Mac OSX
Postby Kunda1 » Fri Dec 15, 2017 10:50 am
Coin version: 3.1.3
If you're going to experiment with FEM then please install the latest dev version per https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
FYI 0.16.6706 is obsolete, the stable is .6712
sbadamik
Re: FEM on Mac OSX
Postby sbadamik » Mon Dec 25, 2017 2:07 pm
I tried going through brew but for some reason, it says that the formula named "calculix-ccx" cannot be found. Any solutions for a beginner?
Re: FEM on Mac OSX
Postby Kunda1 » Mon Dec 25, 2017 11:55 pm
sbadamik
Re: FEM on Mac OSX
Postby sbadamik » Tue Dec 26, 2017 7:56 am
[Solved]: it was because the files weren't in home. Use "brew install Homebrew/homebrew-science/calculix-ccx" instead
Re: FEM on Mac OSX
Postby chrisb » Tue Dec 26, 2017 8:07 am
Good to hear you got it sorted. If you want to mark the discussion as solved, please prepend the text "[solved]" before the subject of your first post.
steeler_fanatic
Re: FEM on Mac OSX
Postby steeler_fanatic » Wed Feb 21, 2018 11:42 pm
Just an update on Bernard's directions...
I went through the install process for calculix today and found out that the "brew install calculix-ccx" will not work without first executing "brew tap brewsci/science". This is because the repository where the formula for installing calculix has been retired and moved to this new location.
:D
