Hello there!
Please find the app using following link:
https://drive.google.com/file/d/0B9ZH5M ... sp=sharing
If it will be find useful and may some usage in FreeCAD development I will provide the code (C#, mono/.net).
regards,
Maciek
adi@vladimir:~/Pobrane$ file mmh_ccx2vtk.exe
mmh_ccx2vtk.exe: PE32 executable (console) Intel 80386 Mono/.Net assembly, for MS Windows
adi@vladimir:~/Pobrane$ ./mmh_ccx2vtk.exe
*** CalculiX output file ".frd" to vtk format converter by [edited]
: Running on Unix 3.19.0.21
! (00) argument not found...
: Usage:
: mmh_ccx2vtk.exe [path]CalculiXoutputFileName.frd
: The [path] string is optional, if not provided assembly will
: try to open specified "frd" file in current directory.
: After succesful conversion the new file will be created using input file name
: with suffix: "_mmh.vtk" in the input directory
: Conversion supports all CalculiX element types and defined number of steps.
: The vector results are transalated as vectors, any other data are treat as scalar
: The name of Nodal Result Block in 'vtk' file and displayed in ParaView is as:
: '[stepn_number]-block_name-item_name' where:
: 'step_number' is the user step number,
: 'block_name' is the name i.e. "DISPR"
: 'item_name' is the item name i.e. "D1"
: It is the .NET/MONO assembly and it should work properly in Linux/Windows environment.
: Please inform me about bugs on mail: [edited]
;) Have a nice step!
: <<<MMH>>>
: press Enter...
Here, Here, Here !!! Do you really use solid geometry in calculix to design reinforced concrete structures and steel structures ? Since I'm structural engineer for concrete structures I'm really really interested in sharing knowledge in this regard.mamah wrote: use the Calculix for reinforced structures design. Is anyone also interested in that? Or in using FreeCAD for any other structural design i.e. steel structures?
I'm interested in composite structures. I have only read about CalculiX possibilities, not tried calculations yet. From my point of view there is a limitation for composites to use quadrilateral elements (S8R) - I will lack a triangular element for complex geometries....to use the Calculix for reinforced structures design. Is anyone also interested in that?
