There's no url to the contents of the libacks, per sey.On Windows it's not necessary to have a compiled NETGEN. From the the libpack we use nglib. I believe there is a .dll in\bin, plus /netgen + /lib and + /include sub-directories. I'll try to make this understandable and post back.Fat-Zer wrote: I don't know a lot about windows build... could you link me to some notes what netgen package looks like there.
Also could you provide CMakeCache.txt and CMakeFiles/CMakeError.log to see what gone wrong...
FindNETGEN rework
Re: FindNETGEN rework
- CMakeCache.txt
- (131.26 KiB) Downloaded 53 times
- CMakeOutput.log
- (22.26 KiB) Downloaded 51 times
- CMakeError.log
- (20.95 KiB) Downloaded 53 times
"fight the good fight"
Ok, on debian based systems, you can query version information for each officially installed package with dpkg:It's true only if package provides version information somehow, e.g. via pkg-config
dpkg -l | grep <package-name>
dpkg -l | grep libavcodec-dev | head -1 | awk '{ print $3; }'
if(NOT CMAKE_BUILD_TYPE)
set(CMAKE_BUILD_TYPE "RelWithDebInfo" CACHE STRING INTERNAL)
endif(NOT CMAKE_BUILD_TYPE)
cmake_minimum_required(VERSION 2.8.9)
project(Netgen)
set(NETGEN_VERSION_MAJOR 6)
set(NETGEN_VERSION_MINOR 1)
set(NETGEN_VERSION "${NETGEN_VERSION_MAJOR}.${NETGEN_VERSION_MINOR}-dev")
set(PACKAGE_VERSION "${NETGEN_VERSION}")
Sad to say - netgens executable is a poor one. It does not support the standard version query like "netgen --version"
OS: Linux Debian Jessie amd64 - FC: Git Master
sgrogan, thanks for your input... It will be helpfull...
Ok, There is one pretty easy to fix:
It just requires zlib... don't know if it will require link to the dll, but yet another find_package() should fix this issue... But I suppose it will break on the the second one issue like two other tests.
But I don't really know what to do with this one:
can somebody point me out whay should I include/define to make the /MDd happy? may be it will be enough to just define _AFXDLL? may it be empty?
I suppose /MDd should be there itself because there are other tests built well with it...
Are there any *{occ,mesh}.{lib,dll} in your netgen distribution? Is it version 5+?
cl /c /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\occ /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\general /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\meshing /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\linalg /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\lib\cmake\..\..\include\oce /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D NETGEN_WITH_OCC /D _DEBUG /D NO_PARALLEL_THREADS /D OCCGEOMETRY /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"cmTryCompileExec2733992907.dir\Debug\\" /Fd"cmTryCompileExec2733992907.dir\Debug\vc120.pdb" /Gd /TP /errorReport:queue "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\src.cxx"
"C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2733992907.vcxproj" (default target) (1) ->
c:\users\chris\desktop\fclibs_vc12_x64\freecadlibs_11.1_x64_vc12\include\netgen\general\gzstream.h(35): fatal error C1083: Cannot open include file: 'zlib.h': No such file or directory [C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2733992907.vcxproj]
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:00.57
Source file was:
#include <occgeom.hpp>
int main() { netgen::OCCGeometry foo; }
ClCompile:
C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\x86_amd64\CL.exe /c /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\general /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D NETGEN_WITH_PARALLEL_THREADS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"cmTryCompileExec2620214328.dir\Debug\\" /Fd"cmTryCompileExec2620214328.dir\Debug\vc120.pdb" /Gd /TP /errorReport:queue "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\src.cxx"
Microsoft (R) C/C++ Optimizing Compiler Version 18.00.31101 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
cl /c /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\general /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D NETGEN_WITH_PARALLEL_THREADS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"cmTryCompileExec2620214328.dir\Debug\\" /Fd"cmTryCompileExec2620214328.dir\Debug\vc120.pdb" /Gd /TP /errorReport:queue "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\src.cxx"
src.cxx
C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\atlmfc\include\afx.h(24): fatal error C1189: #error : Building MFC application with /MD[d] (CRT dll version) requires MFC shared dll version. Please #define _AFXDLL or do not use /MD[d] [C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2620214328.vcxproj]
Done Building Project "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2620214328.vcxproj" (default targets) -- FAILED.
Build FAILED.
"C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2620214328.vcxproj" (default target) (1) ->
(ClCompile target) ->
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:00.43
Source file was:
#include <myadt.hpp>
int main() { netgen::NgMutex foo; }
//Path to a library.
NETGEN_LIBRARY_mesh:FILEPATH=NETGEN_LIBRARY_mesh-NOTFOUND
NETGEN_LIBRARY_occ:FILEPATH=NETGEN_LIBRARY_occ-NOTFOUND
According to the build script it should be 5.1
https://github.com/peterl94/clbundler-f ... /netgen.py
In
LibPack/bin/ there is nglib.dll
In
Libpack/include/netgen/csg
Libpack/include/netgen/meshing
Libpack/include/netgen/occ
etc.
These directories contain only header files (.hpp)
In
Libpack/lib/ there is nglib.lib
In
In
etc.
In
Sorry, that I haven't replied for a while...
I can't fix the test code compilation on MSVC, so I've just disabled it... that should be enough to make it work... please check...
It's not an option to query package manager from cmake...django013 wrote:Ok, on debian based systems, you can query version information for each officially installed package with dpkg:
first, it's only for version six, which is not released yet (at least there is no stable release), 5.x still uses autotools, secondly the CMakeLists.txt is not being installed to the system... so unless upstream will provide it's own FindNETGEN module it's useless...django013 wrote:... by the way: netgen provides version informations in CMakeLists.txt in root directory
even if it were, we couldn't lay on that this executable is installed on the building system due to freecad doesn't depends upon netgen itself, but only on the nglib...django013 wrote:Sad to say - netgens executable is a poor one. It does not support the standard version query like "netgen --version"
Every thing appears to be OK on win.
OS: Windows 7
Version: 0.16.5240 (Git)
Branch: FindNETGEN-rework
Hash: f97593084e371ef2eeec15b0ed56cd41afd033c9
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
OS: Windows 7
Qt version: 4.8.6
Thanks, for testing...
I'll wait for some time if there will be some positive or negative feedbacks from mingw or mac users... And if there won't be any I'll pull-requst...
Could you postpone this until Friday next week or so?
sure, no hurry here...wmayer wrote:Could you postpone this until Friday next week or so?
I can't (was: can) wait to start building FreeCAD rpm packages from the master branch for fedora witn netgen switched on
Edit: Thanks wmayer for catching the typo!
