FindNETGEN rework
Site Admin
Re: FindNETGEN rework
Postby wmayer » Thu Aug 27, 2015 1:19 pm
You can or you can't?
johan
Postby johan » Tue Nov 29, 2016 9:24 pm
Hi there
I just got started with FreeCAD, but I am having some trouble with FindNETGEN on Fedora 23 and getting Netgen to build
As mentioned previously in this post, Fedora names the libraries "ngmesh", "ngocc" and "nginterface" and it seems to use slightly different locations for the header files. I have a temp solution that seems to work (I got freecad compiled with netgen), but I am not sure about the compatibility with other systems. Here goes:
1. In FindNETGEN.cmake, I extend FIND_PATH for nglib.h to also search /usr/include/netgen-mesher
2. Extend FIND_LIBRARY to search both "mesh" and "ngmesh" (similarly for occ and interface)
3. Fedora places NETGENDATA in /usr/include/netgen-mesher/private and not in /usr/share/netgen/libsrc. As I do not know of an elegant way to treat this I use the following cmake command
cmake -DBUILD_FEM_NETGEN=1 -DNETGENDATA="/usr/include/netgen-mesher/private" ../freecad
Or is there perhaps an easier way to get NETGEN working in Fedora which I missed?
PrzemoF
Postby PrzemoF » Fri Dec 02, 2016 7:58 pm
No, I don't think so. The problem keeps coming back [1], so sooner or later it will be solved, but it has to work on 3 systems + multiple distros, so it's not easy to do it right.
[1] viewtopic.php?t=11713
