Which Macro on which FreeCAD ?
The macro from my post viewtopic.php?f=18&t=12355#p99560 works for me on
OS: Windows 7
Version: 0.16.6157 (Git)
Hash: b6faaefaf8adc81bd2f41aebe7516ccd3cbb50a0
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Colorbar macro test
Re: Colorbar macro test
- screen.png (248.9 KiB) Viewed 2231 times
On ubuntu I have problems too:
OS: Ubuntu 15.04
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6188 (Git)
Build type: None
Hash: bf19e80de17454b170cde98df5e4995a7a4991f6
Python version: 2.7.9
Qt version: 4.8.6
File "/home/bhb/.FreeCAD/Mod/Macros/FEM_ColorBAR.FCMacro", line 50, in <module>
ColorMapWidget.setWidget(ColorMap()) # load the Ui script
File "/home/bhb/.FreeCAD/Mod/Macros/FEM_ColorBAR.FCMacro", line 21, in __init__
layout.addWidget(self.canvas)
<type 'exceptions.TypeError'>: 'PySide.QtGui.QBoxLayout.addWidget' called with wrong argument types:
PySide.QtGui.QBoxLayout.addWidget(FigureCanvasQTAgg)
Supported signatures:
PySide.QtGui.QBoxLayout.addWidget(PySide.QtGui.QWidget, int = 0, PySide.QtCore.Qt.Alignment = 0)
Build type: None
Qt version: 4.8.6
My version
OS: Ubuntu 14.04.3 LTS
Version: 0.16.6163 (Git)
Build type: None
Hash: 273131c08857464fe7a140331afc864b7ae752f8
Python version: 2.7.6
Qt version: 4.8.6
Build type: None
Qt version: 4.8.6
Mhh, the addWidget function needs a QWidget but gets a FigureCanvasQTAgg which is returned from matplotlib.pyplot.figure() It seams on Windows this get converted somehow but on Linux we need to take care of this. I have never been working with matplotlib Anyone an idea how to solve this?bernd wrote:Code: Select all
Traceback (most recent call last): File "/home/bhb/.FreeCAD/Mod/Macros/FEM_ColorBAR.FCMacro", line 50, in <module> ColorMapWidget.setWidget(ColorMap()) # load the Ui script File "/home/bhb/.FreeCAD/Mod/Macros/FEM_ColorBAR.FCMacro", line 21, in __init__ layout.addWidget(self.canvas) <type 'exceptions.TypeError'>: 'PySide.QtGui.QBoxLayout.addWidget' called with wrong argument types: PySide.QtGui.QBoxLayout.addWidget(FigureCanvasQTAgg) Supported signatures: PySide.QtGui.QBoxLayout.addWidget(PySide.QtGui.QWidget, int = 0, PySide.QtCore.Qt.Alignment = 0)
I got this working in ubuntu 14.04
It needed :
import os
os.environ['QT_API'] = 'pyside'
It needed :
import os
import sys
import FreeCAD
import FreeCADGui
import os
from PySide import QtGui, QtCore
from matplotlib.backends.backend_qt4agg import FigureCanvasQTAgg as FigureCanvas
import matplotlib.pyplot as plt
import matplotlib as mpl
import numpy as np
class ColorMap(QtGui.QWidget):
def __init__(self, parent=None):
super(ColorMap, self).__init__(parent)
self.figure = plt.figure()
self.canvas = FigureCanvas(self.figure)
self.draw_colormap()
# set the layout
layout = QtGui.QVBoxLayout()
self.setLayout(layout)
def draw_colormap(self):
sel = FreeCADGui.Selection.getSelection() # Selection
if not sel:
QtGui.QMessageBox.critical(None, "ColorMap macro", "An object has to be selected to run")
return
sel1=sel[0]
# Stess Values in MPa
datos=sel1.StressValues
val_max=max(datos)
val_min=min(datos)
# axes
ax = self.figure.add_axes([0.05, 0.10, 0.5, 0.8])
cmap = mpl.cm.jet
norm = mpl.colors.Normalize(vmin=val_min, vmax=val_max)
ticks_cm = np.linspace(val_min, val_max, 10, endpoint=True)
cb1 = mpl.colorbar.ColorbarBase(ax, cmap=cmap,
norm=norm,
ticks=ticks_cm,
orientation='vertical')
label_cm = 'Von Misses Stress [MPa]'
cb1.set_label(label=label_cm,weight='bold')
cb1.ax.tick_params(labelsize=16)
self.canvas.draw()
mw = FreeCADGui.getMainWindow() # access the main window
ColorMapWidget = QtGui.QDockWidget() # create a new dockwidget
mw.addDockWidget(QtCore.Qt.RightDockWidgetArea,ColorMapWidget) # add the widget to the main window
Wow cool works for me to on Debian Jessie and FreeCAD 0.16.6237
BTW:
There is a type in the first line on the first character. It is but should be
You may could edit your post in this regard for others to get it work immediately.
BTW:
mport sys
import sys
Sorry copy paste finger trouble. Post updated
