Hi, I'm trying to make a FEA using TIE to keep joined two parts of an assemblie. In order to generate the groups what I make is put fixed constrains in Freecad and then manually edit the input file to remove it and transform to SURFACES and then apply the TIE command. Problem is that some constrains are not writted in the input file, it generate the FemConstraintFixed, FemConstraintFixed001, skip the 002 and 003, and writtes the 004 and 005.
Any suggestion of what can be wrong? I'm attaching the file if somebody has time to see it. By the way, the Define Node /Element Sets option works? I cannot define the sets in this way.
OS: Windows 7
Version: 0.16.5618 (Git)
Branch: fem_v18
Hash: 173254b510669badb647bef9da2b428f66070df1
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Regards, and thanks in advance
Fixed Restrains not writted in the input file
Engineering Consultor at 4P Ingeniería
http://www.4p-ingenieria.com/
https://www.youtube.com/channel/UClZPfO ... Cx-_J36o_Q
Re: Fixed Restrains not writted in the input file
AFAIK at the moment writing force and fix constraints to the calculix input file is supported only for one FEMMesh in the analysis. If there are more Meshes they are not used to find the node sets. That is probably why some fixed constraints are empty in the input file because the nodes where not found.
Here we are: https://github.com/FreeCAD/FreeCAD/blob ... ls.py#L133
The first FEM Mesh which is found in the Analysis will be taken. All other will be ignored
