TestRequest and CodeReview, Exact cload for edges
I finished the cload implementation for edges. Did some changes in ccxwriter as well
https://github.com/berndhahnebach/FreeC ... loadedge01
http://pha.geofinder.eu/D21
I may add some files to test in another post
Re: TestRequest and CodeReview, Exact cload for edges
some files to test with ...
So much FEM so little time, it's hard to keep up.
I put some win builds here:https://github.com/sgrogan/FreeCAD/rele ... .16-femdev
"fight the good fight"
I'm reading the code and in general it looks fine. I'm not analyzing how it works - it's too much for me today
I found one thing that doesn't look nice - sortlistoflistvalues
I think there is no need to use a new list:
Back to the code...
>>> l = [[1,2,2,0],[2,5,1,2],[3,4,9,3,1],[9,2,5,7]]
>>> for e in l:
... e.sort()
>>> l
[[0, 1, 2, 2], [1, 2, 2, 5], [1, 3, 3, 4, 9], [2, 5, 7, 9]]
Hi, very useful features, those builds are for Windows?
Regards
Regards
Engineering Consultor at 4P Ingeniería
http://www.4p-ingenieria.com/
https://www.youtube.com/channel/UClZPfO ... Cx-_J36o_Q
Yes, I can't build a proper debian or RPM package yet. Let alone an OSX app. So from me its always windows.Serchu wrote:Hi, very useful features, those builds are for Windows?
Please test well. I'm not familiar with the structural workflow w/ beam and shell elements or edge loads. We all need to keep the feature requests to a minimum during testing.
I tried this when I was developing the def. I would swear it did not work when tried itPrzemoF wrote:...I found one thing that doesn't look nice - sortlistoflistvalues
I think there is no need to use a new list:...
I'm gone change it in in further version ...
I cannot find a link, but python sometimes does something unexpected when operating on parameters passed with a function, so you might be right that it doesn't work in a certain situation.
line-load--shell-mesh.fcstd
Seems to work.
line-load--solid-mesh.fcstd
When I run quick analysis "Write .inp file and run Calculix ccx", it gives me result. When I click to "Dialog to start the calculation of the mechanical analysis" it doesn't open task window to start analysis, only reports:
But when I create new MechanicalAnalysis and copy/paste all content to it, all works normally.
line-load--beam-mesh.fcstd
Similar problem with the same error report.
I'm able to do the same trick, but I must create new BeamSetion by hand, because I cannot paste it to the new MechanicalAnalysis.
Last note: I don't see anywhere units for Line load yet.
OS: Windows 7
Version: 0.16.5799 (Git)
Branch: femcloadedge01
Hash: c760f6f9f6620327309868799f5d6161bd447006
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Seems to work.
Running the Python command 'Fem_MechanicalJobControl' failed:
File "D:\soft\FreeCad\FreeCAD_0.16.5799_x64_dev_bin_femcloadedge01\Mod\Fem\_CommandMechanicalJobControl.py", line 48, in Activated
taskd = _JobControlTaskPanel._JobControlTaskPanel(FemGui.getActiveAnalysis())
File "D:\soft\FreeCad\FreeCAD_0.16.5799_x64_dev_bin_femcloadedge01\Mod\Fem\_JobControlTaskPanel.py", line 83, in __init__
self.update()
File "D:\soft\FreeCad\FreeCAD_0.16.5799_x64_dev_bin_femcloadedge01\Mod\Fem\_JobControlTaskPanel.py", line 164, in update
if self.analysis_object.AnalysisType == 'static':
'FeaturePython' object has no attribute 'AnalysisType'
OS: Windows 7
Qt version: 4.8.6
That's OK - there were quite a few changes recently and it's normal and expected behaviour.
If you see any errors after creating the new analysis and moving the content then we have a bug.
