Why does FEM meshing doesn't generate volume elements in some cases
vejmarie
Re: Why does FEM meshing doesn't generate volume elements in some cases
Postby vejmarie » Mon May 02, 2016 6:24 pm
Sorry I didn't see that it didn't found your OpenCascade installation.
Mine is in /usr/local/lib/cmake/opencascade/OpenCASCADEConfig.cmake
It is really strange that the standard script didn't find it. Where is your original OCE installed ? I am getting worried that you had to remove it before installing the new one from OCCT.
bernd
Postby bernd » Tue May 03, 2016 4:49 am
there was something with my occt comile ... OK recompile and make sure all cmake is fine ... It is now. I get linking problems ...
[ 47%] Building CXX object src/TKIVtk/CMakeFiles/TKIVtk.dir/__/IVtkTools/IVtkTools_ShapeObject.cxx.o
[ 47%] Building CXX object src/TKIVtk/CMakeFiles/TKIVtk.dir/__/IVtkTools/IVtkTools_ShapePicker.cxx.o
[ 47%] Building CXX object src/TKIVtk/CMakeFiles/TKIVtk.dir/__/IVtkTools/IVtkTools_SubPolyDataFilter.cxx.o
Linking CXX shared library ../../lin64/gcc/lib/libTKIVtk.so
/usr/bin/ld: cannot find -lvtkRenderingFreeTypeOpenGL
src/TKIVtk/CMakeFiles/TKIVtk.dir/build.make:591: recipe for target 'lin64/gcc/lib/libTKIVtk.so.7.0.0' failed
make[2]: *** [lin64/gcc/lib/libTKIVtk.so.7.0.0] Error 1
CMakeFiles/Makefile2:1340: recipe for target 'src/TKIVtk/CMakeFiles/TKIVtk.dir/all' failed
make[1]: *** [src/TKIVtk/CMakeFiles/TKIVtk.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Searching the internet, I found this library was deleted during update from vtk 6.2 to 6.3 https://github.com/Homebrew/homebrew-sc ... ssues/2852
My first idea was get newer occt, but this is impossible ?! To get access to the github you need to singn an agreement. Hey I do not want write access I just would like to clone the repo ?!? Download of latest occt seams not possible ?!
ickby
Postby ickby » Tue May 03, 2016 5:38 am
You could search the occ cmake variables, freecad does not need the vtk integration and basically does not use the visualisation at all, maybe you can simply deactivate it for compilation. Disclaimer: I never tried it :)
sgrogan
Postby sgrogan » Tue May 03, 2016 11:33 am
bernd wrote:My first idea was get newer occt, but this is impossible ?! To get access to the github you need to singn an agreement. Hey I do not want write access I just would like to clone the repo ?!? Download of latest occt seams not possible ?!
You can download snapshot of OCCT master here:http://git.dev.opencascade.org/gitweb/? ... git;a=tree
bernd
Postby bernd » Tue May 03, 2016 2:26 pm
sgrogan wrote:You can download snapshot of OCCT master here:http://git.dev.opencascade.org/gitweb/? ... git;a=tree
Thanks, I missed that snapshot button somehow ! :D Latest occt is compiling and has passed the linking vtkRenderingFreeTypeOpenGL problem. But it takes so long on my poor laptop ...
sgrogan
Postby sgrogan » Tue May 03, 2016 3:28 pm
bernd wrote: Latest occt is compiling and has passed the linking vtkRenderingFreeTypeOpenGL problem. But it takes so long on my poor laptop ...
I'm getting the linking problem
OCCT HEAD 7856b12, VTK 7.0.0 (self compiled w/python bindings), FreeCAD LibPack 11.2, VC12_x64 release
Error	1	error LNK1181: cannot open input file 'vtkRenderingOpenGL.lib'	C:\Users\sim\Documents\SW_Projects\OCCT-build\src\TKIVtk\LINK	TKIVtk
Error	2	error LNK1181: cannot open input file '..\..\win64\vc12\lib\TKIVtk.lib'	C:\Users\sim\Documents\SW_Projects\OCCT-build\src\TKIVtkDraw\LINK	TKIVtkDraw
OCCT compiled with no errors with VTK disabled. Investigating further.
EDIT: looks like the lib has a new name
vtkRenderingOpenGL2-7.0.lib
vejmarie
Postby vejmarie » Tue May 03, 2016 5:53 pm
Hi sgrogan,
Yes they changed the name of the library, that is currently an issue within the CMake file of OCCT. So you can edit it by hand, and go straight forward.
@benrd, I hope that you have an SSD drive, as compiling everything is about 3 hours on my MacbookPro (latest version with 16GB)
vejmarie
sgrogan
Postby sgrogan » Tue May 03, 2016 8:29 pm
vejmarie wrote:So you can edit it by hand, and go straight forward.
Thanks
Do you mean the Cmake file? If so I can't find this in any of the Cmake files.
Or edit the file name of the library. If so I assume both the .lib and .dll.
bernd
Postby bernd » Wed May 04, 2016 4:59 am
It took more than 4 hours on my 6 years old ThinkPad X301, but soon I will get hands on brand newest gerneration Thinkpad x1 carbon with ssd on pcie :D
Back to occt, taking the up to date snapshot it compiles flawless on debian jessie. I can run drawexe. :D
OK FreeCAD first without netgen !
cmake searches for OPENCASCADEConfig.cmake or opencascade-config.cmake but it is named OpenCASCADEConfig.cmake for me. I made a symbolic link by
ln -s /usr/local/lib/cmake/opencascade/OpenCASCADEConfig.cmake /usr/local/lib/cmake/opencascade/opencascade-config.cmake
cmake ../ gives now
OCE_DIR /usr/lib/x86_64-linux-gnu/oce-0.15
OPENCASCADE_DIR /usr/local/lib/cmake/opencascade
I tried to change OCE_DIR to opencascade libs with
$ cmake  -DOCE_DIR=/usr/local/lib  ../
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: /usr/local/lib
-- Boost version: 1.55.0
-- Found the following Boost libraries:
--   filesystem
--   program_options
--   regex
--   signals
--   system
--   thread
-- Found Xerces-C: /usr/lib/x86_64-linux-gnu/libxerces-c.so
-- PyCXX found:
--   Headers:  /home/hugo/Documents/dev/freecad/freecadbhb_vejmarie/src
--   Sources:  /home/hugo/Documents/dev/freecad/freecadbhb_vejmarie/src/CXX
-- -- OpenCASCADE Community Edition has been found.
-- -- Found OCE/OpenCASCADE version: 6.7.0
-- -- OCE/OpenCASCADE include directory: /usr/lib/x86_64-linux-gnu/oce-0.15/../../../include/oce
-- -- OCE/OpenCASCADE shared libraries directory:
-- checking for module 'Coin'
--   package 'Coin' not found
-- libshiboken built for Release
-- Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc
-- -- matplotlib-1.4.2 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type:
git
/home/hugo/Documents/dev/freecad/freecadbhb_vejmarie/build/src/Build/Version.h written
CMake Error at /usr/local/lib/cmake/opencascade/OpenCASCADEApplicationFrameworkTargets.cmake:34 (message):
  Some (but not all) targets in this export set were already defined.
  Targets Defined:
  TKCDF;TKLCAF;TKCAF;TKBinL;TKXmlL;TKBin;TKXml;FWOSPlugin;TKTObj;TKBinTObj;TKXmlTObj
  Targets not yet defined: TKStdL;TKStd;TKVCAF
  /usr/local/lib/cmake/opencascade/opencascade-config.cmake:89 (include)
  src/3rdParty/salomesmesh/CMakeLists.txt:21 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/hugo/Documents/dev/freecad/freecadbhb_vejmarie/build/CMakeFiles/CMakeOutput.log".
See also "/home/hugo/Documents/dev/freecad/freecadbhb_vejmarie/build/CMakeFiles/CMakeError.log".
I seams my lack off cmake to tell FreeCAD it should use my pretty new installed occt 7 :(
vejmarie
Postby vejmarie » Wed May 04, 2016 6:47 am
Hi Bernd,
This is because the CMake procedure is always looking for OCE before OCCT implementation.
So you can comment as a temporary fix into FindOpenCasCade.cmake the line 26 # find_package(OCE QUIET)
Then give it a try and you might be ok.
vejmarie
