Why does FEM meshing doesn't generate volume elements in some cases
vejmarie
Re: Why does FEM meshing doesn't generate volume elements in some cases
Postby vejmarie » Fri May 06, 2016 4:06 pm
bernd wrote:
vejmarie wrote:Try with export CPP_FLAGS=/usr/include/GL in your environment before launching configure and make
No it does not work. I changed the code.
changed in libsrc/include/incvis.hpp
#    include <glu.h>
to
#    include <GL/glu.h>
but now ...
go@weide:~/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1$ make
make  all-recursive
make[1]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1'
Making all in libsrc
make[2]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc'
Making all in general
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/general'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/general'
Making all in gprim
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/gprim'
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/gprim'
Making all in linalg
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/linalg'
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/linalg'
Making all in include
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/include'
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/include'
Making all in meshing
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/meshing'
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/meshing'
Making all in interface
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/interface'
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/interface'
Making all in csg
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/csg'
/bin/bash ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../..  -I../../libsrc/include  -I"/usr/include/tcl8.6"   -DNGLIB_EXPORTS -fopenmp -MT vscsg.lo -MD -MP -MF .deps/vscsg.Tpo -c -o vscsg.lo vscsg.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../.. -I../../libsrc/include -I/usr/include/tcl8.6 -DNGLIB_EXPORTS -fopenmp -MT vscsg.lo -MD -MP -MF .deps/vscsg.Tpo -c vscsg.cpp  -fPIC -DPIC -o .libs/vscsg.o
mv -f .deps/vscsg.Tpo .deps/vscsg.Plo
/bin/bash ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../..  -I../../libsrc/include  -I"/usr/include/tcl8.6"   -DNGLIB_EXPORTS -fopenmp -MT csgpkg.lo -MD -MP -MF .deps/csgpkg.Tpo -c -o csgpkg.lo csgpkg.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../.. -I../../libsrc/include -I/usr/include/tcl8.6 -DNGLIB_EXPORTS -fopenmp -MT csgpkg.lo -MD -MP -MF .deps/csgpkg.Tpo -c csgpkg.cpp  -fPIC -DPIC -o .libs/csgpkg.o
mv -f .deps/csgpkg.Tpo .deps/csgpkg.Plo
/bin/bash ../../libtool --tag=CXX   --mode=link g++  -DNGLIB_EXPORTS -fopenmp   -o libcsgvis.la -rpath /opt/netgen/lib vscsg.lo csgpkg.lo libcsg.la
libtool: link: rm -fr  .libs/libcsgvis.la .libs/libcsgvis.lai .libs/libcsgvis.so .libs/libcsgvis.so.0 .libs/libcsgvis.so.0.0.0
libtool: link: g++  -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.9/crtbeginS.o  .libs/vscsg.o .libs/csgpkg.o   -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/csg/.libs -Wl,-rpath -Wl,/opt/netgen/lib ./.libs/libcsg.so -L/usr/lib/gcc/x86_64-linux-gnu/4.9 -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../.. -lstdc++ -lm -lgomp -lpthread -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.9/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu/crtn.o  -fopenmp   -fopenmp -Wl,-soname -Wl,libcsgvis.so.0 -o .libs/libcsgvis.so.0.0.0
libtool: link: (cd ".libs" && rm -f "libcsgvis.so.0" && ln -s "libcsgvis.so.0.0.0" "libcsgvis.so.0")
libtool: link: (cd ".libs" && rm -f "libcsgvis.so" && ln -s "libcsgvis.so.0.0.0" "libcsgvis.so")
libtool: link: ( cd ".libs" && rm -f "libcsgvis.la" && ln -s "../libcsgvis.la" "libcsgvis.la" )
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/csg'
Making all in geom2d
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/geom2d'
/bin/bash ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../..  -I../../libsrc/include  -I"/usr/include/tcl8.6"   -DNGLIB_EXPORTS -fopenmp -MT geom2dpkg.lo -MD -MP -MF .deps/geom2dpkg.Tpo -c -o geom2dpkg.lo geom2dpkg.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../.. -I../../libsrc/include -I/usr/include/tcl8.6 -DNGLIB_EXPORTS -fopenmp -MT geom2dpkg.lo -MD -MP -MF .deps/geom2dpkg.Tpo -c geom2dpkg.cpp  -fPIC -DPIC -o .libs/geom2dpkg.o
mv -f .deps/geom2dpkg.Tpo .deps/geom2dpkg.Plo
/bin/bash ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../..  -I../../libsrc/include  -I"/usr/include/tcl8.6"   -DNGLIB_EXPORTS -fopenmp -MT vsgeom2d.lo -MD -MP -MF .deps/vsgeom2d.Tpo -c -o vsgeom2d.lo vsgeom2d.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../.. -I../../libsrc/include -I/usr/include/tcl8.6 -DNGLIB_EXPORTS -fopenmp -MT vsgeom2d.lo -MD -MP -MF .deps/vsgeom2d.Tpo -c vsgeom2d.cpp  -fPIC -DPIC -o .libs/vsgeom2d.o
mv -f .deps/vsgeom2d.Tpo .deps/vsgeom2d.Plo
/bin/bash ../../libtool --tag=CXX   --mode=link g++  -DNGLIB_EXPORTS -fopenmp   -o libgeom2dvis.la -rpath /opt/netgen/lib geom2dpkg.lo vsgeom2d.lo libgeom2d.la
libtool: link: rm -fr  .libs/libgeom2dvis.la .libs/libgeom2dvis.lai .libs/libgeom2dvis.so .libs/libgeom2dvis.so.0 .libs/libgeom2dvis.so.0.0.0
libtool: link: g++  -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.9/crtbeginS.o  .libs/geom2dpkg.o .libs/vsgeom2d.o   -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/geom2d/.libs -Wl,-rpath -Wl,/opt/netgen/lib ./.libs/libgeom2d.so -L/usr/lib/gcc/x86_64-linux-gnu/4.9 -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../.. -lstdc++ -lm -lgomp -lpthread -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.9/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu/crtn.o  -fopenmp   -fopenmp -Wl,-soname -Wl,libgeom2dvis.so.0 -o .libs/libgeom2dvis.so.0.0.0
libtool: link: (cd ".libs" && rm -f "libgeom2dvis.so.0" && ln -s "libgeom2dvis.so.0.0.0" "libgeom2dvis.so.0")
libtool: link: (cd ".libs" && rm -f "libgeom2dvis.so" && ln -s "libgeom2dvis.so.0.0.0" "libgeom2dvis.so")
libtool: link: ( cd ".libs" && rm -f "libgeom2dvis.la" && ln -s "../libgeom2dvis.la" "libgeom2dvis.la" )
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/geom2d'
Making all in occ
make[3]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/occ'
/bin/bash ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../..  -I../../libsrc/include  -DOCCGEOMETRY -I/opt/OpenCASCADE/inc -I/usr/local/include/opencascade -D_OCC64 -DHAVE_IOSTREAM -DHAVE_LIMITS -DHAVE_LIMITS_H -DHAVE_IOMANIP -I"/usr/include/tcl8.6"   -DNGLIB_EXPORTS -fopenmp -MT Partition_Inter2d.lo -MD -MP -MF .deps/Partition_Inter2d.Tpo -c -o Partition_Inter2d.lo Partition_Inter2d.cxx
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../.. -I../../libsrc/include -DOCCGEOMETRY -I/opt/OpenCASCADE/inc -I/usr/local/include/opencascade -D_OCC64 -DHAVE_IOSTREAM -DHAVE_LIMITS -DHAVE_LIMITS_H -DHAVE_IOMANIP -I/usr/include/tcl8.6 -DNGLIB_EXPORTS -fopenmp -MT Partition_Inter2d.lo -MD -MP -MF .deps/Partition_Inter2d.Tpo -c Partition_Inter2d.cxx  -fPIC -DPIC -o .libs/Partition_Inter2d.o
In file included from /usr/include/c++/4.9/type_traits:35:0,
                 from /usr/local/include/opencascade/Standard_Handle.hxx:21,
                 from /usr/local/include/opencascade/Standard_Type.hxx:19,
                 from /usr/local/include/opencascade/BRepAlgo_AsDes.hxx:21,
                 from Partition_Inter2d.jxx:31,
                 from Partition_Inter2d.ixx:28,
                 from Partition_Inter2d.cxx:33:
/usr/include/c++/4.9/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support for the \
In file included from /usr/local/include/opencascade/Standard_Type.hxx:19:0,
/usr/local/include/opencascade/Standard_Handle.hxx:29:49: error: expected template-name before '<' token
   struct is_base_but_not_same : std::is_base_of <T1, T2> {};
/usr/local/include/opencascade/Standard_Handle.hxx:29:49: error: expected '{' before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:29:49: error: expected unqualified-id before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:54: error: 'enable_if' in namespace 'std' does not name a template type
   struct is_base_but_not_same <T1, T2, typename std::enable_if <std::is_same <T1, T2>::value>::type> : std::false_type {};
/usr/local/include/opencascade/Standard_Handle.hxx:34:64: error: expected template-argument before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:64: error: expected '>' before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:100: error: template argument 3 is invalid
/usr/local/include/opencascade/Standard_Handle.hxx:34:102: error: expected '::' before ':' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:102: error: expected identifier before ':' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:102: error: qualified name does not name a class before ':' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:102: error: expected '{' before ':' token
/usr/local/include/opencascade/Standard_Handle.hxx:34:102: error: expected unqualified-id before ':' token
/usr/local/include/opencascade/Standard_Handle.hxx:73:19: error: expected ',' or '...' before '&&' token
     handle (handle&& theHandle) : entity(theHandle.entity)
/usr/local/include/opencascade/Standard_Handle.hxx:73:31: error: invalid constructor; you probably meant 'opencascade::handle<T> (const opencascade::handle<T>&)'
/usr/local/include/opencascade/Standard_Handle.hxx:114:30: error: expected ',' or '...' before '&&' token
     handle& operator= (handle&& theHandle)
/usr/local/include/opencascade/Standard_Handle.hxx:186:26: error: 'enable_if' in namespace 'std' does not name a template type
     static typename std::enable_if<is_base_but_not_same<T2, T>::value, handle>::type
/usr/local/include/opencascade/Standard_Handle.hxx:186:35: error: expected unqualified-id before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:194:26: error: 'enable_if' in namespace 'std' does not name a template type
/usr/local/include/opencascade/Standard_Handle.hxx:194:35: error: expected unqualified-id before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:203:72: error: 'enable_if' in namespace 'std' does not name a template type
     static handle DownCast (const handle<T2>& theObject, typename std::enable_if<!is_base_but_not_same<T2, T>::value, void*>::type = 0)
/usr/local/include/opencascade/Standard_Handle.hxx:203:81: error: expected ',' or '...' before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:211:61: error: 'enable_if' in namespace 'std' does not name a template type
     static handle DownCast (const T2* thePtr, typename std::enable_if<!is_base_but_not_same<T2, T>::value, void*>::type = 0)
/usr/local/include/opencascade/Standard_Handle.hxx:211:70: error: expected ',' or '...' before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:221:31: warning: explicit conversion operators only available with -std=c++11 or -std=gnu++11
     explicit operator bool () const
/usr/local/include/opencascade/Standard_Handle.hxx:281:50: error: 'enable_if' in namespace 'std' does not name a template type
     template <class T2, typename = typename std::enable_if<is_base_but_not_same<T2, T>::value>::type>
/usr/local/include/opencascade/Standard_Handle.hxx:281:59: error: expected '>' before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:282:35: error: default template arguments may not be used in function templates without -std=c++11 or -std=gnu++11
     operator const handle<T2>& () const
/usr/local/include/opencascade/Standard_Handle.hxx:289:50: error: 'enable_if' in namespace 'std' does not name a template type
/usr/local/include/opencascade/Standard_Handle.hxx:289:59: error: expected '>' before '<' token
/usr/local/include/opencascade/Standard_Handle.hxx:290:27: error: default template arguments may not be used in function templates without -std=c++11 or -std=gnu++11
     operator handle<T2>& ()
/usr/local/include/opencascade/Standard_Handle.hxx: In member function 'opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>)':
/usr/local/include/opencascade/Standard_Handle.hxx:116:32: error: 'theHandle' was not declared in this scope
       std::swap (this->entity, theHandle.entity);
/usr/local/include/opencascade/Standard_Handle.hxx: In member function 'opencascade::handle<T>::operator bool() const':
/usr/local/include/opencascade/Standard_Handle.hxx:223:24: error: 'nullptr' was not declared in this scope
       return entity != nullptr;
In file included from /usr/local/include/opencascade/NCollection_TListIterator.hxx:19:0,
                 from /usr/local/include/opencascade/NCollection_List.hxx:19,
                 from /usr/local/include/opencascade/TopoDS_ListOfShape.hxx:20,
                 from /usr/local/include/opencascade/TopoDS_TShape.hxx:23,
                 from /usr/local/include/opencascade/TopoDS_Shape.lxx:17,
                 from /usr/local/include/opencascade/TopoDS_Shape.hxx:242,
                 from /usr/local/include/opencascade/TopTools_DataMapOfShapeListOfShape.hxx:20,
                 from /usr/local/include/opencascade/BRepAlgo_AsDes.hxx:23,
/usr/local/include/opencascade/NCollection_BaseList.hxx: In constructor 'NCollection_BaseList::NCollection_BaseList(const opencascade::handle<NCollection_BaseAllocator>&)':
/usr/local/include/opencascade/NCollection_BaseList.hxx:137:17: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'const opencascade::handle<NCollection_BaseAllocator>')
     myAllocator = (theAllocator.IsNull() ? NCollection_BaseAllocator::CommonBaseAllocator() : theAllocator);
/usr/local/include/opencascade/NCollection_BaseList.hxx:137:17: note: candidates are:
/usr/local/include/opencascade/Standard_Handle.hxx:100:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(const opencascade::handle<T>&) [with T = NCollection_BaseAllocator]
     handle& operator= (const handle& theHandle)
/usr/local/include/opencascade/Standard_Handle.hxx:114:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>) [with T = NCollection_BaseAllocator; opencascade::handle<T> = opencascade::handle<NCollection_BaseAllocator>]
In file included from /usr/local/include/opencascade/TopoDS_Shape.hxx:242:0,
/usr/local/include/opencascade/TopoDS_Shape.lxx: In member function 'void TopoDS_Shape::EmptyCopy()':
/usr/local/include/opencascade/TopoDS_Shape.lxx:435:12: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<TopoDS_TShape>' and 'opencascade::handle<TopoDS_TShape>')
   myTShape = myTShape->EmptyCopy();
/usr/local/include/opencascade/TopoDS_Shape.lxx:435:12: note: candidates are:
/usr/local/include/opencascade/Standard_Handle.hxx:100:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(const opencascade::handle<T>&) [with T = TopoDS_TShape]
/usr/local/include/opencascade/Standard_Handle.hxx:114:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>) [with T = TopoDS_TShape; opencascade::handle<T> = opencascade::handle<TopoDS_TShape>]
/usr/local/include/opencascade/TopoDS_Shape.lxx: In member function 'void TopoDS_Shape::TShape(const opencascade::handle<TopoDS_TShape>&)':
/usr/local/include/opencascade/TopoDS_Shape.lxx:457:12: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<TopoDS_TShape>' and 'const opencascade::handle<TopoDS_TShape>')
   myTShape = TS;
/usr/local/include/opencascade/TopoDS_Shape.lxx:457:12: note: candidates are:
In file included from /usr/local/include/opencascade/NCollection_DataMap.hxx:19:0,
                 from /usr/local/include/opencascade/TopTools_DataMapOfShapeListOfShape.hxx:23,
/usr/local/include/opencascade/NCollection_BaseMap.hxx: In constructor 'NCollection_BaseMap::NCollection_BaseMap(Standard_Integer, Standard_Boolean, const opencascade::handle<NCollection_BaseAllocator>&)':
/usr/local/include/opencascade/NCollection_BaseMap.hxx:166:17: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'const opencascade::handle<NCollection_BaseAllocator>')
/usr/local/include/opencascade/NCollection_BaseMap.hxx:166:17: note: candidates are:
In file included from /usr/local/include/opencascade/TopoDS_Builder.hxx:130:0,
                 from /usr/local/include/opencascade/BRep_Builder.hxx:24,
                 from Partition_Inter2d.cxx:40:
/usr/local/include/opencascade/TopoDS_Builder.lxx: In member function 'void TopoDS_Builder::MakeWire(TopoDS_Wire&) const':
/usr/local/include/opencascade/TopoDS_Builder.lxx:37:17: error: no matching function for call to 'TopoDS_Builder::MakeShape(TopoDS_Wire&, opencascade::handle<TopoDS_TWire>&) const'
   MakeShape(W,TW);
/usr/local/include/opencascade/TopoDS_Builder.lxx:37:17: note: candidate is:
In file included from /usr/local/include/opencascade/BRep_Builder.hxx:24:0,
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note: void TopoDS_Builder::MakeShape(TopoDS_Shape&, const opencascade::handle<TopoDS_TShape>&) const
   Standard_EXPORT void MakeShape (TopoDS_Shape& S, const Handle(TopoDS_TShape)& T) const;
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<TopoDS_TWire>' to 'const opencascade::handle<TopoDS_TShape>&'
/usr/local/include/opencascade/TopoDS_Builder.lxx: In member function 'void TopoDS_Builder::MakeShell(TopoDS_Shell&) const':
/usr/local/include/opencascade/TopoDS_Builder.lxx:49:17: error: no matching function for call to 'TopoDS_Builder::MakeShape(TopoDS_Shell&, opencascade::handle<TopoDS_TShell>&) const'
   MakeShape(S,TS);
/usr/local/include/opencascade/TopoDS_Builder.lxx:49:17: note: candidate is:
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<TopoDS_TShell>' to 'const opencascade::handle<TopoDS_TShape>&'
/usr/local/include/opencascade/TopoDS_Builder.lxx: In member function 'void TopoDS_Builder::MakeSolid(TopoDS_Solid&) const':
/usr/local/include/opencascade/TopoDS_Builder.lxx:60:17: error: no matching function for call to 'TopoDS_Builder::MakeShape(TopoDS_Solid&, opencascade::handle<TopoDS_TSolid>&) const'
   MakeShape(S,TS);
/usr/local/include/opencascade/TopoDS_Builder.lxx:60:17: note: candidate is:
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<TopoDS_TSolid>' to 'const opencascade::handle<TopoDS_TShape>&'
/usr/local/include/opencascade/TopoDS_Builder.lxx: In member function 'void TopoDS_Builder::MakeCompSolid(TopoDS_CompSolid&) const':
/usr/local/include/opencascade/TopoDS_Builder.lxx:71:17: error: no matching function for call to 'TopoDS_Builder::MakeShape(TopoDS_CompSolid&, opencascade::handle<TopoDS_TCompSolid>&) const'
   MakeShape(C,TC);
/usr/local/include/opencascade/TopoDS_Builder.lxx:71:17: note: candidate is:
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<TopoDS_TCompSolid>' to 'const opencascade::handle<TopoDS_TShape>&'
/usr/local/include/opencascade/TopoDS_Builder.lxx: In member function 'void TopoDS_Builder::MakeCompound(TopoDS_Compound&) const':
/usr/local/include/opencascade/TopoDS_Builder.lxx:83:17: error: no matching function for call to 'TopoDS_Builder::MakeShape(TopoDS_Compound&, opencascade::handle<TopoDS_TCompound>&) const'
   MakeShape(C,TC);
/usr/local/include/opencascade/TopoDS_Builder.lxx:83:17: note: candidate is:
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<TopoDS_TCompound>' to 'const opencascade::handle<TopoDS_TShape>&'
In file included from /usr/local/include/opencascade/BRep_TFace.hxx:114:0,
                 from /usr/local/include/opencascade/BRep_Builder.lxx:19,
                 from /usr/local/include/opencascade/BRep_Builder.hxx:274,
/usr/local/include/opencascade/BRep_TFace.lxx: In member function 'void BRep_TFace::Surface(const opencascade::handle<Geom_Surface>&)':
/usr/local/include/opencascade/BRep_TFace.lxx:68:13: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<Geom_Surface>' and 'const opencascade::handle<Geom_Surface>')
   mySurface = S;
/usr/local/include/opencascade/BRep_TFace.lxx:68:13: note: candidates are:
/usr/local/include/opencascade/Standard_Handle.hxx:100:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(const opencascade::handle<T>&) [with T = Geom_Surface]
/usr/local/include/opencascade/Standard_Handle.hxx:114:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>) [with T = Geom_Surface; opencascade::handle<T> = opencascade::handle<Geom_Surface>]
/usr/local/include/opencascade/BRep_TFace.lxx: In member function 'void BRep_TFace::Triangulation(const opencascade::handle<Poly_Triangulation>&)':
/usr/local/include/opencascade/BRep_TFace.lxx:78:19: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<Poly_Triangulation>' and 'const opencascade::handle<Poly_Triangulation>')
   myTriangulation = T;
/usr/local/include/opencascade/BRep_TFace.lxx:78:19: note: candidates are:
/usr/local/include/opencascade/Standard_Handle.hxx:100:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(const opencascade::handle<T>&) [with T = Poly_Triangulation]
/usr/local/include/opencascade/Standard_Handle.hxx:114:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>) [with T = Poly_Triangulation; opencascade::handle<T> = opencascade::handle<Poly_Triangulation>]
In file included from /usr/local/include/opencascade/BRep_Builder.hxx:274:0,
/usr/local/include/opencascade/BRep_Builder.lxx: In member function 'void BRep_Builder::MakeFace(TopoDS_Face&) const':
/usr/local/include/opencascade/BRep_Builder.lxx:32:17: error: no matching function for call to 'BRep_Builder::MakeShape(TopoDS_Face&, opencascade::handle<BRep_TFace>&) const'
   MakeShape(F,TF);
/usr/local/include/opencascade/BRep_Builder.lxx:32:17: note: candidate is:
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<BRep_TFace>' to 'const opencascade::handle<TopoDS_TShape>&'
/usr/local/include/opencascade/BRep_Builder.lxx: In member function 'void BRep_Builder::MakeVertex(TopoDS_Vertex&) const':
/usr/local/include/opencascade/BRep_Builder.lxx:212:17: error: no matching function for call to 'BRep_Builder::MakeShape(TopoDS_Vertex&, opencascade::handle<BRep_TVertex>&) const'
   MakeShape(V,TV);
/usr/local/include/opencascade/BRep_Builder.lxx:212:17: note: candidate is:
/usr/local/include/opencascade/TopoDS_Builder.hxx:116:24: note:   no known conversion for argument 2 from 'opencascade::handle<BRep_TVertex>' to 'const opencascade::handle<TopoDS_TShape>&'
In file included from /usr/local/include/opencascade/NCollection_Sequence.hxx:19:0,
                 from /usr/local/include/opencascade/IntRes2d_SequenceOfIntersectionPoint.hxx:21,
                 from /usr/local/include/opencascade/IntRes2d_Intersection.hxx:25,
                 from /usr/local/include/opencascade/IntCurve_IntImpConicParConic.hxx:24,
                 from /usr/local/include/opencascade/IntCurve_IntConicConic.hxx:24,
                 from /usr/local/include/opencascade/Geom2dInt_GInter.hxx:25,
                 from /usr/local/include/opencascade/TopOpeBRep_EdgesIntersector.hxx:31,
                 from Partition_Inter2d.cxx:47:
/usr/local/include/opencascade/NCollection_BaseSequence.hxx: In constructor 'NCollection_BaseSequence::NCollection_BaseSequence(const opencascade::handle<NCollection_BaseAllocator>&)':
/usr/local/include/opencascade/NCollection_BaseSequence.hxx:115:17: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'const opencascade::handle<NCollection_BaseAllocator>')
/usr/local/include/opencascade/NCollection_BaseSequence.hxx:115:17: note: candidates are:
In file included from /usr/local/include/opencascade/TopTools_DataMapOfShapeListOfShape.hxx:20:0,
/usr/local/include/opencascade/TopoDS_Shape.hxx: In member function 'TopoDS_Shape& TopoDS_Shape::operator=(const TopoDS_Shape&)':
/usr/local/include/opencascade/TopoDS_Shape.hxx:46:7: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<TopoDS_TShape>' and 'const opencascade::handle<TopoDS_TShape>')
 class TopoDS_Shape
/usr/local/include/opencascade/TopoDS_Shape.hxx:46:7: note: candidates are:
In file included from Partition_Inter2d.jxx:40:0,
/usr/local/include/opencascade/TopoDS_Vertex.hxx: In member function 'TopoDS_Vertex& TopoDS_Vertex::operator=(const TopoDS_Vertex&)':
/usr/local/include/opencascade/TopoDS_Vertex.hxx:35:7: note: synthesized method 'TopoDS_Shape& TopoDS_Shape::operator=(const TopoDS_Shape&)' first required here
 class TopoDS_Vertex  : public TopoDS_Shape
In file included from /usr/local/include/opencascade/TopOpeBRep_Point2d.hxx:166:0,
                 from /usr/local/include/opencascade/TopOpeBRep_SequenceOfPoint2d.hxx:20,
                 from /usr/local/include/opencascade/TopOpeBRep_EdgesIntersector.hxx:36,
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx: In member function 'void TopOpeBRep_Point2d::SetVertex(Standard_Integer, const TopoDS_Vertex&)':
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx:77:35: note: synthesized method 'TopoDS_Vertex& TopoDS_Vertex::operator=(const TopoDS_Vertex&)' first required here
   if      (Index == 1) {myvertex1 = V; myisvertex1 = Standard_True;}
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx: In member function 'void TopOpeBRep_Point2d::SetHctxff2d(const opencascade::handle<TopOpeBRep_Hctxff2d>&)':
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx:289:13: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<TopOpeBRep_Hctxff2d>' and 'const opencascade::handle<TopOpeBRep_Hctxff2d>')
   myctxff2d = h;
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx:289:13: note: candidates are:
/usr/local/include/opencascade/Standard_Handle.hxx:100:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(const opencascade::handle<T>&) [with T = TopOpeBRep_Hctxff2d]
/usr/local/include/opencascade/Standard_Handle.hxx:114:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>) [with T = TopOpeBRep_Hctxff2d; opencascade::handle<T> = opencascade::handle<TopOpeBRep_Hctxff2d>]
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx: In member function 'void TopOpeBRep_Point2d::SetHctxee2d(const opencascade::handle<TopOpeBRep_Hctxee2d>&)':
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx:307:13: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<TopOpeBRep_Hctxee2d>' and 'const opencascade::handle<TopOpeBRep_Hctxee2d>')
   myctxee2d = h;
/usr/local/include/opencascade/TopOpeBRep_Point2d.lxx:307:13: note: candidates are:
/usr/local/include/opencascade/Standard_Handle.hxx:100:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(const opencascade::handle<T>&) [with T = TopOpeBRep_Hctxee2d]
/usr/local/include/opencascade/Standard_Handle.hxx:114:13: note: opencascade::handle<T>& opencascade::handle<T>::operator=(opencascade::handle<T>) [with T = TopOpeBRep_Hctxee2d; opencascade::handle<T> = opencascade::handle<TopOpeBRep_Hctxee2d>]
In file included from /usr/include/c++/4.9/bits/stl_pair.h:59:0,
                 from /usr/include/c++/4.9/bits/stl_algobase.h:64,
                 from /usr/include/c++/4.9/bits/char_traits.h:39,
                 from /usr/include/c++/4.9/ios:40,
                 from /usr/include/c++/4.9/ostream:38,
                 from /usr/include/c++/4.9/iostream:39,
                 from ../../libsrc/include/mystdlib.h:9,
                 from Partition_Inter2d.jxx:27,
/usr/include/c++/4.9/bits/move.h: In instantiation of 'void std::swap(_Tp&, _Tp&) [with _Tp = opencascade::handle<NCollection_BaseAllocator>]':
/usr/local/include/opencascade/NCollection_BaseMap.hxx:209:49:   required from here
/usr/include/c++/4.9/bits/move.h:176:11: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'opencascade::handle<NCollection_BaseAllocator>')
       __a = _GLIBCXX_MOVE(__b);
/usr/include/c++/4.9/bits/move.h:176:11: note: candidates are:
/usr/include/c++/4.9/bits/move.h:177:11: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'opencascade::handle<NCollection_BaseAllocator>')
       __b = _GLIBCXX_MOVE(__tmp);
/usr/include/c++/4.9/bits/move.h:177:11: note: candidates are:
In file included from /usr/local/include/opencascade/IntRes2d_SequenceOfIntersectionPoint.hxx:21:0,
/usr/local/include/opencascade/NCollection_Sequence.hxx: In instantiation of 'void NCollection_Sequence<TheItemType>::Clear(const opencascade::handle<NCollection_BaseAllocator>&) [with TheItemType = IntRes2d_IntersectionSegment]':
/usr/local/include/opencascade/IntRes2d_Intersection.lxx:73:16:   required from here
/usr/local/include/opencascade/NCollection_Sequence.hxx:170:25: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'const opencascade::handle<NCollection_BaseAllocator>')
       this->myAllocator = theAllocator;
/usr/local/include/opencascade/NCollection_Sequence.hxx:170:25: note: candidates are:
/usr/local/include/opencascade/NCollection_Sequence.hxx: In instantiation of 'void NCollection_Sequence<TheItemType>::Clear(const opencascade::handle<NCollection_BaseAllocator>&) [with TheItemType = IntRes2d_IntersectionPoint]':
/usr/local/include/opencascade/IntRes2d_Intersection.lxx:74:16:   required from here
In file included from /usr/local/include/opencascade/TopoDS_ListOfShape.hxx:20:0,
/usr/local/include/opencascade/NCollection_List.hxx: In instantiation of 'void NCollection_List<TheItemType>::Clear(const opencascade::handle<NCollection_BaseAllocator>&) [with TheItemType = TopoDS_Shape]':
/usr/local/include/opencascade/NCollection_List.hxx:275:11:   required from 'NCollection_List<TheItemType>::~NCollection_List() [with TheItemType = TopoDS_Shape]'
/usr/local/include/opencascade/TopoDS_TShape.lxx:40:42:   required from here
/usr/local/include/opencascade/NCollection_List.hxx:98:25: error: ambiguous overload for 'operator=' (operand types are 'opencascade::handle<NCollection_BaseAllocator>' and 'const opencascade::handle<NCollection_BaseAllocator>')
/usr/local/include/opencascade/NCollection_List.hxx:98:25: note: candidates are:
Makefile:427: recipe for target 'Partition_Inter2d.lo' failed
make[3]: *** [Partition_Inter2d.lo] Error 1
make[3]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/occ'
Makefile:311: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc'
Makefile:354: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1'
Makefile:285: recipe for target 'all' failed
make: *** [all] Error 2
hugo@weide:~/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1$
That's a different issue ;). I am using llvm on MacOS. So on linux we got GCC. Can you try to add this switch -std=gnu++11 within the compiler option ?
vejmarie
bernd
Postby bernd » Fri May 06, 2016 4:34 pm
vejmarie wrote:That's a different issue ;). I am using llvm on MacOS. So on linux we got GCC. Can you try to add this switch -std=gnu++11 within the compiler option ?
I knew it was somethin different but had no glue what, again thanks.
./configure  --enable-occ  --enable-shared  --enable-nglib  CXXFLAGS=-DNGLIB_EXPORTS CXXFLAGS="-std=gnu++11"
did it
my needy little lenovo x301 is running for hours on 100% :o :shock: 8-) :mrgreen:
FreeCAD occt7 is on 60% compiling, netgen still compiling too and in between I do some small fixes in multiple solver ...
It's really time to set up the new lenovo X1 with linux. It still is windows only.
cheers bernd
bernd
Postby bernd » Fri May 06, 2016 4:38 pm
next issue on netgen, linking problems ...
/bin/bash ../libtool --tag=CXX   --mode=link g++  -std=gnu++11 -fopenmp -export-dynamic  -o netgen demoview.o ngappinit.o onetcl.o parallelfunc.o ngpkg.o ../libsrc/visualization/libvisual.la ../libsrc/csg/libcsgvis.la ../libsrc/csg/libcsg.la ../libsrc/interface/libinterface.la ../libsrc/meshing/libmesh.la -L/usr/lib/Togl1.7  -lTogl -lGLU -L/usr/lib/x86_64-linux-gnu -ltk8.6 -L/usr/lib/x86_64-linux-gnu -ltcl8.6    -lGL -lXmu -lX11
libtool: link: g++ -std=gnu++11 -fopenmp -o .libs/netgen demoview.o ngappinit.o onetcl.o parallelfunc.o ngpkg.o -Wl,--export-dynamic  ../libsrc/visualization/.libs/libvisual.a ../libsrc/csg/.libs/libcsgvis.so ../libsrc/csg/.libs/libcsg.so ../libsrc/interface/.libs/libinterface.so ../libsrc/meshing/.libs/libmesh.so -L/usr/lib/Togl1.7 -lTogl -lGLU -L/usr/lib/x86_64-linux-gnu -ltk8.6 -ltcl8.6 -lGL -lXmu -lX11 -fopenmp -Wl,-rpath -Wl,/opt/netgen/lib
/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib/libTogl.so: undefined reference to `Tk_InitStubs'
/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib/libTogl.so: undefined reference to `tkStubsPtr'
/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib/libTogl.so: undefined reference to `Tcl_InitStubs'
/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib/libTogl.so: undefined reference to `tclStubsPtr'
Makefile:414: recipe for target 'netgen' failed
make[2]: *** [netgen] Error 1
make[2]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/ng'
vejmarie
Postby vejmarie » Fri May 06, 2016 5:37 pm
You are just missing the tcl/tk libraries into the link phase not a major issue will ne back home in 1 hour and will guide you !
vejmarie
Postby vejmarie » Fri May 06, 2016 6:34 pm
@bernd, do you have this kind of option within your netgen configure (you need to adapt depending on where tcl and tk stands)
./configure --with-tcl=/opt/local/lib --with-tk=/opt/local/lib --enable-occ --with-tclinclude=/opt/local/include --enable-shared --enable-nglib CXXFLAGS="-DNGLIB_EXPORTS"
vejmarie
Postby vejmarie » Sat May 07, 2016 8:31 am
Do not forget to keep -std=gnu++11 in CXXFLAGS
solofo
Postby solofo » Sat May 07, 2016 7:05 pm
@bernd
netgen 5.3.1 (from @vejmarie github) needs tcl/tk 8.5, it does not seem to work with 8.6
Cf.:
https://sourceforge.net/p/netgen-mesher ... /6b00b981/
http://stackoverflow.com/questions/2633 ... references
solofo
Postby solofo » Sun May 08, 2016 7:54 am
Also had to add libraries by hand in Makefile for nglib:
OCCLIBS = -L/home/solofo/SOFTWARE/install/opencascade-7.0.0/lib -lTKV3d -lTKService -lTKHLR -lTKVCAF -lTKCAF -lTKCDF -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTK
Mesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin
to solve these issues:
/bin/bash ../libtool --tag=CXX --mode=link g++ -g -O2 -fopenmp -std=gnu++11 -o ng_vol ng_vol.o libnglib.la ../libsrc/interface/libinterface.la ../libsrc/geom2d/libgeom2d.la ../libsrc/csg/libcsg.la ../libsrc/stlgeom/libstl.la ../libsrc/occ/libocc.la ../libsrc/meshing/libmesh.la -L/home/solofo/SOFTWARE/install/opencascade-7.0.0/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin
libtool: link: g++ -g -O2 -fopenmp -std=gnu++11 -o .libs/ng_vol ng_vol.o ./.libs/libnglib.so ../libsrc/interface/.libs/libinterface.so ../libsrc/geom2d/.libs/libgeom2d.so ../libsrc/csg/.libs/libcsg.so ../libsrc/stlgeom/.libs/libstl.so ../libsrc/occ/.libs/libocc.so ../libsrc/meshing/.libs/libmesh.so -L/home/solofo/SOFTWARE/install/opencascade-7.0.0/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin -fopenmp -Wl,-rpath -Wl,/home/solofo/SOFTWARE/install/netgen-5.3.1/lib
/usr/bin/ld: warning: libTKV3d.so.7, needed by /home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKMeshVS.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libTKService.so.7, needed by /home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKMeshVS.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libTKHLR.so.7, needed by /home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKMeshVS.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libTKVCAF.so.7, needed by /home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKXDESTEP.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libTKCAF.so.7, needed by /home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKXDESTEP.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libTKCDF.so.7, needed by /home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKXDESTEP.so, not found (try using -rpath or -rpath-link)
/home/solofo/SOFTWARE/install/opencascade-7.0.0/lib/libTKLCAF.so: undefined reference to `CDM_Document::IsStored() const'
[ ... lots of undefined reference ...]
vejmarie
Postby vejmarie » Sun May 08, 2016 7:57 am
@solofo, that is probably because you didn't installed the library on a standard directory on your system ;)
You might be facing some challenges at FreeCAD link which requires also the TK* libraries
bernd
Postby bernd » Sun May 08, 2016 1:52 pm
I'm on the way for the weekend ...
@solofo: just some hint. if you would use the code tags from the forum editor for code or bash output your posts would be much better readable for others and for yourself. You can even edit your own published posts in this regard.
bernd
