Fem constraint contact
makkemal
Re: Fem constraint contact
Postby makkemal » Fri Jun 24, 2016 8:33 am
Hi bernd
Good to see you doing FEM on some pressure parts :D
The branch you committed works with all the test problems I have and the results are correct.
Thanks for helping with the fixes.
The error you are getting with the split file commit is just because the test file is old and the analysis is still named Mechanical Analysis.
just change its name to Analysis.
The split did have a few other errors, please see just updated.
I attach a test file for testing that commit.
Beam_bend_transient_contact.fcstd
(83.79 KiB) Downloaded 34 times
bernd
Postby bernd » Fri Jun 24, 2016 2:12 pm
makkemal wrote:The error you are getting with the split file commit is just because the test file is old and the analysis is still named Mechanical Analysis.
Ahh it works now, thanks. We should not rely on object names. That's exactly the kind of problems I do not like to see in master. We only have a chance to find such problems before we merge into master is splitting the huge thermomech commit.
cheers bernd
PrzemoF
Postby PrzemoF » Fri Jun 24, 2016 2:58 pm
Feel free to use http://pha.geofinder.eu/ for code reviews. Its back online.
bernd
Postby bernd » Fri Jun 24, 2016 3:04 pm
PrzemoF wrote:Feel free to use http://pha.geofinder.eu/ for code reviews. Its back online.
Wow cool, good to know !
bernd
Postby bernd » Fri Jun 24, 2016 4:55 pm
http://pha.geofinder.eu/D43
ToDo:
- fix fem unit test
makkemal
Postby makkemal » Sat Jun 25, 2016 5:08 am
ToDo:
- fix fem unit test
How do you do a unit test ?
The current units has problems when you add Joules and Watts for themomechanical.
I will have vdwalts pull that out of step 1 post it and explain what is going on so we don't duplicate work
bernd
Postby bernd » Sun Jun 26, 2016 6:15 am
ToDo:
- fix fem unit test
done
makkemal wrote:How do you do a unit test ?
- start FreeCAD
- change to workbench Test framework --> click on icon "Self-test"
- change from TestApp.all. to TestFem
- click on Start
The FEM unit teste are implemented on the module TestFem.py Would be good to have some more for the new constraints.
bernd
Postby bernd » Sun Jun 26, 2016 5:02 pm
find the begin of splitting the huge thermomech commit to add the thermomech constraints in a new branch:
https://github.com/berndhahnebach/FreeC ... mechanical
https://github.com/makkemal/FreeCAD/commits/rtd_vdwalts was used for splitting
bernd
Postby bernd » Wed Jul 13, 2016 6:14 pm
development branch for all new constraints:
https://github.com/berndhahnebach/FreeC ... onstraints
- constraint contact
- constraint plane rotation
- thermomechanical analysis
It's not yet ready, but I see light at the end of the darkness ...
Shockley
Postby Shockley » Sun Sep 25, 2016 11:52 pm
makkemal wrote:@vejmarie
compile this tree
https://github.com/makkemal/FreeCAD/tree/rtd_hindlemp
example attached
@bernd don't look at the code or how the commits are staged :twisted:
I've downloaded the example project and opened it on FreeCAD 0.17 but the solver object doesn't run this Calculix object has less parameters than the solver that I can create with FreeCAD (I think this is easier to explain with images...).
PS: Finally I've could run the simulation on FreeCAD 0.17 32bit on windows 10 (32bit), I've had create a new analysis in te project with a new solver and after move all the constraints and meshes from one analysis to another analysis object. I don't know if this success is due to I use windows this time or because on the previous simulations I didn't use other object analysis for run the solver, yet. But one thing is clear, simulations on FreeCAD are still an odissey.
