Fem constraint contact
PrzemoF
Re: Fem constraint contact
Postby PrzemoF » Mon Sep 26, 2016 4:40 pm
ccx path is not set in my case (for testing purpose) and:
$ bin/FreeCAD ~/Downloads/contact_example.FCStd
FreeCAD 0.17, Libs: 0.17R8509 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
Using CalculiX binary path from FEM preferences: /home/przemo/software/FreeCAD/CalculiX/bin/ccx
FemTools.setup_working_dir()  -->  self.working_dir = /tmp
'FemToolsCcx' object has no attribute 'ccx_binary'Traceback (most recent call last):
  File "/home/przemo/software/FreeCAD/build/Mod/Fem/_TaskPanelFemSolverCalculix.py", line 186, in write_input_file_handler
    if self.check_prerequisites_helper():
  File "/home/przemo/software/FreeCAD/build/Mod/Fem/_TaskPanelFemSolverCalculix.py", line 208, in check_prerequisites_helper
    fea = FemToolsCcx.FemToolsCcx(None, self.solver_object)
  File "/home/przemo/software/FreeCAD/build/Mod/Fem/FemToolsCcx.py", line 79, in __init__
    self.setup_ccx()
  File "/home/przemo/software/FreeCAD/build/Mod/Fem/FemToolsCcx.py", line 150, in setup_ccx
    format(ccx_binary, ccx_stdout, ccx_binary_sig))
Exception: FEM: CalculiX ccx 'None' output 'None' doesn't contain expected phrase 'CalculiX'. Please use ccx 2.6 or newer
OS: "Fedora release 24 (Twenty Four)"
Version: 0.17.8509 (Git)
Build type: Unknown
Hash: e4a086752f96823c43586ea88c73ab7c81ebbd13
Python version: 2.7.12
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
bernd
Postby bernd » Mon Sep 26, 2016 7:58 pm
PrzemoF wrote:ccx path is not set in my case (for testing purpose) and:
I can reproduce the issue on
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.8507 (Git)
Build type: Unknown
Hash: cb3da6ff9c45fe5726ad0d17580ebe6636b3ea55
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
If in preferences the check box use standard path is activated I get the same error. Funny thing is if the path is empty and the checkbox is not set it works fine for me. We need to have a look on this.
bernd
Postby bernd » Tue Sep 27, 2016 4:42 am
PrzemoF
Postby PrzemoF » Tue Sep 27, 2016 8:05 am
I managed to break it :-) If there is no ccx at all (one of my test setups) FreeCAD stays on checking dependencies with no error and command line shows this:
[przemo@localhost build]$ bin/FreeCAD /media/sf_Transfer/FC/contact_example.FCStd
FreeCAD 0.17, Libs: 0.17R8510 +1 (Git)
which: no ccx in (/home/przemo/software/FreeCAD/build/bin:/home/przemo/software/FreeCAD/build/Mod/Sketcher:/home/przemo/software/FreeCAD/build/Mod/ReverseEngineering:/home/przemo/software/FreeCAD/build/Mod/Show:/home/przemo/software/FreeCAD/build/Mod/Image:/home/przemo/software/FreeCAD/build/Mod/PartDesign:/home/przemo/software/FreeCAD/build/Mod/Measure:/home/przemo/.FreeCAD/Mod/FreeCAD_assembly2:/home/przemo/software/FreeCAD/build/Mod/Ship:/home/przemo/software/FreeCAD/build/Mod/Plot:/home/przemo/software/FreeCAD/build/Mod/MeshPart:/home/przemo/software/FreeCAD/build/Mod/OpenSCAD:/home/przemo/software/FreeCAD/build/Mod/Fem:/home/przemo/software/FreeCAD/build/Mod/Spreadsheet:/home/przemo/software/FreeCAD/build/Mod/Start:/home/przemo/software/FreeCAD/build/Mod/Draft:/home/przemo/software/FreeCAD/build/Mod/Test:/home/przemo/software/FreeCAD/build/Mod/Import:/home/przemo/software/FreeCAD/build/Mod/TechDraw:/home/przemo/software/FreeCAD/build/Mod/Complete:/home/przemo/software/FreeCAD/build/Mod/Web:/home/przemo/software/FreeCAD/build/Mod/Material:/home/przemo/software/FreeCAD/build/Mod/Raytracing:/home/przemo/software/FreeCAD/build/Mod/Mesh:/home/przemo/software/FreeCAD/build/Mod/Path:/home/przemo/software/FreeCAD/build/Mod/Part:/home/przemo/software/FreeCAD/build/Mod/Arch:/home/przemo/software/FreeCAD/build/Mod/Robot:/home/przemo/software/FreeCAD/build/Mod/Points:/home/przemo/software/FreeCAD/build/Mod/Idf:/home/przemo/software/FreeCAD/build/Mod/Inspection:/home/przemo/software/FreeCAD/build/Mod/Drawing:/usr/lib64/ccache:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/home/przemo/.local/bin:/home/przemo/bin)
I didn't test it, but if I had ccx somewhere it would work :D
Failed "which" sets exit code to 1 - it can be used to tell there is no ccx on the system:
[przemo@localhost freecad]$ which ccx
/usr/bin/which: no ccx in (/usr/lib64/ccache:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/home/przemo/.local/bin:/home/przemo/bin)
[przemo@localhost freecad]$ echo $?
1
Shockley
Postby Shockley » Tue Sep 27, 2016 5:22 pm
bernd wrote:
Shockley wrote:FEM wb works fine on FreeCAD 0.17-8508 win 32bit version
Great
Shockley wrote:but FEM wb doesn't work on FreeCAD 0.17-8508 Linux 64 bit.
Does the contact example does not work for you on Linux or does FEMWB at all does not work on Linux. You can test easily by:
- start FreeCAD
- change to start workbench
- load 3d FEM example
- run Calculations
Does it create a Result for you on Linux?
Fixed!!
I've change the standard calculix path given by FreeCAD for "/usr/bin/ccx" I don't know why it error happen but after change the path the simulation works fine.
My system is:
OS: "Linux Mint 17.3 "Rosa""
Build type: Unknown
I have one more question, Have you got this displacement when you run the simulation on your computer? (It seems going on the worng direction but I don't know).
Shockley
Postby Shockley » Tue Sep 27, 2016 9:42 pm
Cool sim achieved with FreeCAD
bernd
Postby bernd » Wed Sep 28, 2016 5:33 am
Shockley wrote:I have one more question, Have you got this displacement when you run the simulation on your computer? (It seems going on the worng direction but I don't know).
Yes it moves up! The displacement constraint moves the half sphere up. As soon as the half sphere has contact with the cantilever it moves the cantilever up. The pressure is just another stiffness which results in more stress introduced by the moving up of the half sphere. Hope this explains it. BTW: great to see some one new using FEM.
There have been some changes, fixes and new features commited to FreeCAD master in the regard of FEM. I recommend to upgrade to at least 0.17.8537
bernd
Postby bernd » Wed Sep 28, 2016 5:38 am
PrzemoF wrote:I managed to break it :-) If there is no ccx at all (one of my test setups) FreeCAD stays on checking dependencies with no error and command line shows this:
1
I did not test without ccx. I will have a look. BTW on my system (debian jessie) it gives without ccx:
FemTools.setup_working_dir()  -->  self.working_dir = /tmp/FEMWB/
Running the Python command 'Fem_RunSolver' failed:
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/_CommandRunSolver.py", line 59, in Activated
    self.fea = FemToolsCcx.FemToolsCcx(None, self.solver)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/FemToolsCcx.py", line 79, in __init__
    self.setup_ccx()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/FemToolsCcx.py", line 120, in setup_ccx
    self.ccx_binary = ccx_path
local variable 'ccx_path' referenced before assignment
Shockley
Postby Shockley » Wed Sep 28, 2016 5:48 pm
I've FreeCAD Daily version but the lastest update for me is 0.17-8509 version I've the PPAs added to my computer for every day update, I guess that in windows updates are published first and after the update come to the PPAs for the Linux version, it has one day of delay (at least for me) between windows and Linux version.
bernd
Postby bernd » Thu Sep 29, 2016 4:24 pm
Fixed. Are you still able to break it? https://github.com/berndhahnebach/FreeC ... athonlinux
