Multiselect
Rei
Multiselect
Postby Rei » Sat May 28, 2016 7:36 pm
Hi everyone. It was recommended that I post here and reference this thread:
viewtopic.php?f=3&t=15916
In terms of features, the ability to do multiselect would be greatly appreciated. With any sort of complex model, it could take ages to assign forces across a large section of it. Eg:
https://c2.staticflickr.com/8/7099/2669 ... 72a1_o.png
(Also, if anyone here could weigh in on some of the issues trying to get results out of FEA being discussed over there, that'd be great :) )
bernd
Re: Multiselect
Postby bernd » Sun May 29, 2016 8:34 pm
I havn't read the thread, will do on Monday.
In the regard of multiselection. Do you mean something like this ...
# load FEM example
# copy code to console
shape_obj = App.ActiveDocument.getObject("Box")
ref1 = [(shape_obj, ('Face3', 'Face6', 'Face2', 'Face4', 'Face5'))]
App.ActiveDocument.getObject("FemConstraintForce").References = ref1
or with multiple selection:
# load FEM example
# make Cube visible
# make Box_Mesh not visible
# select all the faces
# copy code
sel = Gui.Selection.getSelectionEx()[0]
ref2 = [(sel.Object, sel.SubElementNames)]
App.ActiveDocument.getObject("FemConstraintForce").References = ref2
add force to lots of faces at once ...
bernd
Re: Multiselect
Postby bernd » Mon May 30, 2016 11:03 am
A more sophisticated example ... Attached two files.
The constraint force is applied to one face only. Just click around and run the analysis … Nothing difficault. Let's start playing … We would like to apply the force to all (ALL) the triangles (2837 faces).
load constraint_force--1_face.FCStd
We gone make a compound of all faces we would like to use for the constraint …
obj = App.ActiveDocument.getObjectsByLabel('terrain')[0]
faces = []
for f in obj.Shape.Faces:
    add_face = True
    for v in f.Vertexes:
        if v.Z < 100100:
             add_face = False
             print v.Z
    if add_face is True:
        if f not in faces:
            faces.append(f)
Part.show(Part.makeCompound(faces))
Add all faces of the compound to the constraint force
fpart = App.ActiveDocument.getObjectsByLabel('Shape')[0]
cfaceslist = []
for fno in range(len(fpart.Shape.Faces)):
    cfaceslist.append('Face' + str(fno+1))
cfaces = tuple(cfaceslist)
ref = [(fpart, cfaces)]
cforce =  App.ActiveDocument.getObjectsByLabel('FemConstraintForce')[0]
cforce.References = ref
cforce.References
Run the analysis. Writing the file takes some time for me (ca 11 minutes). File constraint_force--2837_faces.FCStd is what I get.
https://cloud.woelkli.com/index.php/s/f3JV2XmrgRaAHm5
https://cloud.woelkli.com/index.php/s/iOy0DTkwZ6JORD9
Rei
Re: Multiselect
Postby Rei » Mon May 30, 2016 10:25 pm
Thanks, I'll give that a try whenever I can get my actual model to a non-crashy state :)
bernd
Re: Multiselect
Postby bernd » Tue May 31, 2016 5:21 pm
I encountered a problem with the FEM constraints and lot's of shapes. Attached a file wich has 109 faces addes. Double click on FemConstraintForce and click on ok. Attached the error screen. It is a GUI problem only. More reference shapes could be added by python without any problems. See above posts (2837 faces where added by python).
code to change the reference faces off the force constraint:
count_faces = len(fpart.Shape.Faces)   # 121
# count_faces = 109  # 108 faces is still ok for the gui
cfaceslist = []
for fno in range(count_faces):
# cforce.References = []
cforce.References
OS: Debian GNU/Linux 8.4 (jessie)
Version: 0.17.7687 (Git)
Build type: Unknown
Hash: d6f31d5c4b673ae87df0e113724de9fa34cf4d63
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.7.0
constraint_force--max_faces_test.FCStd
(68.76 KiB) Downloaded 27 times
makkemal
Re: Multiselect
Postby makkemal » Wed Jun 01, 2016 2:56 am
I agree with this, look at how the prescribed displacement is setup which allows for multiple selections.
The new constraints we are adding works the same.
We have also modified pressure to do it in the same manner
bernd
Re: Multiselect
Postby bernd » Wed Jun 01, 2016 4:32 am
makkemal wrote:I agree with this, look at how the prescribed displacement is setup which allows for multiple selections.
Same problem on prescribed displacement. If dozens of faces are added by python the gui gives errors.
#count_faces = 109
cfaceslist = []
cdisp =  App.ActiveDocument.getObjectsByLabel('FemConstraintDisplacement')[0]
cdisp.References = ref
cdisp.References
Site Admin
Re: Multiselect
Postby wmayer » Sat Jun 04, 2016 7:44 am
The limiting factor is the function Command::doCommand. Internally it reserves memory buffer of a length of 4063. However, the passed string seems to be longer so that afterwards the created Python command is truncated, hence the "invalid syntax" error.
Since the you can pass an arbitrary number of arguments to doComand() it's not that easy to determine the requested size of the output string. I have to check if there is a good solution...
Site Admin
Re: Multiselect
Postby wmayer » Sat Jun 04, 2016 8:37 am
bernd
Re: Multiselect
Postby bernd » Sun Jun 05, 2016 7:43 pm
wmayer wrote:git commit 3c269f4
Wow, even the file with the 2837 reference shapes works. :D It takes some time but it works.
Thanks werner for giving the description what the problem is, ähhm was !
